필요한 것
동영상 개요
댓글 8개
When I reassembled my Moto X 2nd gen. after a battery change, I lost audio to the speaker. Audio jack works fine. Nothing is torn, but definitely something loose or not connected. I don't know where to look. Could you please help guide me to where it might be? Thanks!
I have a solution to the speaker not working after putting the phone back together.
The speaker wasn't connecting with the metal tabs on the phone back panel due to my replacement battery being a little thicker.
I was able to bend the speaker contact pins to connects with the relevant connectors and it started working. Slightly hacky but worked. I have posted pictures https://plus.google.com/+BenSycha/posts/...
@wasrel Where did you purchase a replaccement battery and was it new?
Same problem. What is the answer?
I found a solution, look at my reply to phamtoan.
thanks. it works again. made it with a little piece of metal film
What is the screw type (the thread size and length) for the screws that hold the phone together? I somehow messed up the screw heads beyond repair, even though I had a correct screw driver :(
