소개
What does $12.5 billion dollars buy you nowadays? In Google's case, it buys Motorola, Inc. and all of its designs and patents. Is it what we would have spent the money on? Probably not, but the result of the acquisition is Motorola's first smartphone, designed and assembled in the United States—the Moto X.
Keep it goofy with us on Instagram, get serious with our Facebook, or make it short and sweet with a tweet. Your choice.
필요한 것
동영상 개요
The love child of Motorola and Google is here, and we are dying to crack open the little Motoroogle.
Technical Specifications:
Dual-core 1.7 GHz Qualcomm Snapdragon S4 Pro processor
2 GB RAM
4.7-inch 1280x720 pixels AMOLED display
16 or 32 GB internal storage
Qualcomm Adreno 320 GPU
10 MP rear-facing camera
The top of the Moto X houses the centered headphone jack. We haven't seen this placement on too many recent smartphones.
Since we tend to have a lot of devices laying around, we might as well do some comparisons! The Moto X is certainly not small, but it is a bit smaller than the S4, and we are fans of the contoured back.
This is the first and only smartphone that's "Designed & Assembled in the USA," to our knowledge.
Snap snap SNAP!
The melodious sound of easy teardown access fills our ears as we release clips holding the rear panel in place.
What is this? Google! Motorola! How could you do this to us?
To our dismay, the unexpectedly flexible rear panel, though clipped to the device, is also adhered. Time to bring in some reinforcements.
*note* If you don't use a wide prying tool (Like the one in the picture), you will likely crack the outside edge of the back cover.
Jason Ross - 답글
Fake rubbery carbon back cover is harder to remove than the stiffer pink back cover variant:
It uses two layers of glue in between a silicon buffer, the glue pad on the outer side sticks way better to the rubber than the layer that adheres to the nfc antenna/battery. Danger here is the connecting element for the camera flash being sandwiched here also,
is more fragile during the removal (due to bendiness) at weak points like the volume buttons and the first points near the SIM slot. Make sure the glue got warm enough.
이 단계에 사용된 도구:iOpener$19.99
Designed to penetrate the impenetrable, to de-here the adhered, to unfasten the hard-fastened, the iOpener has yet to meet gobs of adhesive it couldn't handle.
Whilst removing the rear panel, we get our first glimpse at the NFC antenna.
Obviously the phone you tore down was saturated with glue... but I don't think they all are. I've torn down 5-6 of these devices and not run into the glue yet (the back just pops off super clean and easy). The phones I attacked were couple of custom colored ones from the online store and a handful of "developer edition phones". Maybe the glue is just on the stock / mass produced variant?
I had a first run version and it had lots of adhesive just like their teardown model.
Even after defeating Big Blue, the rear panel still does not yield.
We release the ZIF connector of a big ol' rear-case-mounted flash assembly, and after 6 full steps, we are finally into the device.
Our "Woven Black" case has a nice weave. While it's probably not actual kevlar fibers, the molding makes for a nice view — you can see right through it!
The pattern of these NFC coils triggers some powerful nostalgia.
Snap back to reality, there go the volume and sleep buttons, all on one handy cable.
I miss my slot cars! Kids today have no idea how cool it was to start out with a basic one and step up to customizing everything, from motor to gear ratio, and to get crazy with a custom painted molded chassis.
Those were the days. Tiger milk!
"We'll just wrestle this battery off here…Or not."
Time to chase down the end of the NFC antenna ribbon cable.
We interrogate the antenna assembly about the whereabouts of the cable's end. Nothing like a 54 Bit Driver Kit to encourage stubborn hardware.
Eureka! Adios, battery!
What´s the size of the torx screws?
This is a teardown, not meant to be followed for repairs. Check out the Moto X device page for step-by-step repair guides and more detail, like the sizes of certain screws!
Motorola claims the Moto X battery can power through an amazing 24 hours of "mixed usage."
How does the Moto X accomplish such a feat with a 3.8 volt, 2200 mAh Lithium ion battery? The secret is in the X8 Mobile Computing System.
Motorola developed a custom system architecture, which, when coupled with eight processor cores, allows for the delegation of processing power:
4 graphics processor cores for "stunning clarity"
2 application processor cores for "swift action"
2 low-power cores—"awaiting your next command"
Out comes the upper midframe panel, housing the speaker, headphone jack, more antennas, and pressure contacts.
Yay, pressure contacts! We like spring pressure contacts because they don't require any work to disconnect.
This is possibly the most modular headphone jack we've ever seen. It pops right out of the upper midframe panel, spring contacts and all.
A spudger helps us unclip a small microphone board from the earpiece speaker.
The microphone assembly clings (like a baby sloth) to the earpiece speaker to maintain a solid connection with the spring contacts below.
Naturally, we love design innovation. We can tell that a considerable amount of effort went in to the internal design of this device; the number of clips and contacts we've found so far is a great testament to that.
이 단계에 사용된 도구:Precision Tweezers Set$9.95
After selecting our favorite pair of precision tweezers, we remove the 2 MP front-facing camera from the Moto X.
The front-facing camera is labeled as 84016172 REV A 0054067 01017429 142-3.
이 단계에 사용된 도구:Soldering Workstation$49.99
The motherboard is ours for the taking, and take we will. Let's just hope there's a little more excitement on the other side of the board.
Alas, the streets of this circuit city are looking a little bare. We're going to guess there's a lot more fun to be found under the myriad EMI shields. Only one way to find out…
Before we can fully examine the motherboard, though, we must remove the 10 megapixel rear-facing camera.
10 MP is 25% more pixels than the camera in the iPhone 5, but isn't quite on the Lumia 1020's level, though we can hardly fault it for that.
Notable ICs on the motherboard:
Toshiba THGBMAG7A2JBAIR 16 GB eMMC NAND Flash
SK Hynix H9TKNNNBPDAR RAM (we assume that the Snapdragon S4 Pro is also layered under this IC)
Qualcomm PM8921 Power Management IC
Texas Instruments TMS320C55 Digital Signal Processor
NXP 44701 NFC Chip
Skyworks 77619-12 Multiband Multimode Power Amplifier Module for Quad-Band GSM / EDGE and Penta-Band (Bands I, II, IV, V, VIII) WCDMA/ HSDPA/ HSUPA/ HSPA+/ LTE
Texas Instruments MSP430 F5259 Mixed Signal Microcontroller
Additional ICs:
Qualcomm WCD9310 Audio Codec
Qualcomm WCN3680 802.11ac Combo Wi-Fi/Bluetooth/FM
NXP TFA9890 High Efficiency Class-D Audio Amplifier
Skyworks 77737 SkyHi™ Power Amplifier Module for LTE Bands 12/17 (698-716 MHz)
EPCOS 7959 Wireless LAN/Bluetooth Filters (IF)
Qualcomm WTR16505L LTE/HSPA+/CDMA2K/TDSCDMA/EDGE/GPS Transceiver
Teardown update: We got ahold of a Verizon version of the Moto-X and played a little game of 'spot the difference' with the motherboard:
SanDisk SDIN8DE2-16G 16 GB NAND Flash replaces the Toshiba
Samsung K3PE0E00QM-CGC2 2 GB LPDDR2 RAM instead of SK Hynix
The Verizon model adds another Qualcomm modem, the WTR1605 (in addition to the WTR1606L, possibly used solely for LTE support on this model)
The back of the motherboard may look bare, but upon closer inspection we found two microphones:
Wolfson Microelectronics WM7121 Top Port Analogue Silicon Microphone
Wolfson Microelectronics WM7132 Bottom Port Analogue Silicon Microphone
Motoroogle again shows off its novelty; the X's vibrator motor is soldered right to the motherboard. The wonders never cease.
Like any good warrior, we hold onto the
earsEMI shields of our enemies.
The mobo is no mo', and we get to examine the backside of the display assembly, which is adorned by some nice comfy foam.
One thing about this device is certain: the design choices are nothing if not unique. The midframe is held in place by pins protruding from the edges of the display assembly bezel.
How to disassemble frame from the display module assembly?
Do I need any special tool?
The hefty display cable assembly is home to the Synaptics touchscreen controller.
Rumor has it that there's some magic in this display glass, we don't see anything special, what do your elf eyes see?
Don't buy the replacement glass only from ebay, buy the glass + frame. You will see that the glass only has a "lip" for the plastic mold to mold over, which is something most of us cannot do. Also, beware that the glass over the front camera, make sure it is NOT tinted before install... The one I got has "tint" over it, which is actually meant for the proximity sensor (IR)
Glass+frame is the way to go if just the Glass is broken, but LCD and touch still work.
You also don't need to disassemble it completely. Only open the bottom two torx screws, then heat up the glass and carefully remove the glass parts from the panel and frame. Pry off the the old frame but don't loose the bolts, you'll need them. Ebay frames+glass come without bolts.
Motorola Moto X Repairability Score: 7 out of 10 (10 is easiest to repair)
Pressure contacts and cable connectors make the modular components (cameras, buttons, headphone jack and speakers) easy to replace.
The Moto X uses a single kind of screw, although it's a fairly uncommon size (T3).
The taped-in battery is less accessible than we'd like, but at least it's near the top of the stack once you get the rear cover off (as opposed to the HTC One).
The digitizer is fused to the display, increasing repair costs for a cracked screen. But the display midframe can be separated, potentially lowering the cost of the replacement part.
Sticky adhesive on the back cover is annoying and will slow opening the phone.
댓글 35개
To your question "Does it make more sense than a headphone jack on the bottom of a phone? Only time will tell…(but yes, it probably makes more sense)." I strongly agree; I would suggest that it is much better to have the phone in your pocket with the earbud wire coming out the top than for the connector/wire to be bent/stressed down at the bottom of your pocket.
Does anyone know where I can find the plastic/rubber gasket piece that sits over the proximity sensor. I've had the careless misfortune of losing not 1 but 2 of these during past services on this model, and have discovered them to be vital in the operation of the proximity sensor and thus the phone itself.
I filed a slot in them and used a straight screwdriver to remove.... might be hard to do with some of the screws that are down in holes.
Wonder why they didn't connect or enable the radio chip so that users could utilize radio tuner onboard? I' told moto G has it, but my moto X (1st gen) does not.
Geo Sept 5, 2015
snodgrassg - 답글
So i tore mine down to replace the glass.. i think i missed something -0 because now it will do everything by make calls... screen goes black and no volume when call is made.
Any suggestions on what i'm missing?
Is vibrator motor repairable/replacable ?
Recently I have been using it on vibration mode and now I think its damaged and it sounds weak and deteriorated.
Do I need a T3 Torx or a T4 Torx to remove the eleven screws in order to replace the screen assembly? The new assembly was advertised with tools but they aren't the right size. >:( Everywhere I am looking is saying T4 Torx, but I have half the mind to think you are the accurate one. Can anyone confirm that the T3 is what I need to order?
Which antenna is the GPS antenna? My Moto X seems to show less GPS signal strength compared to others I have compared it to using same signal test app.
My moto X won't charge anymore due to a broken uUSB charging connector. I believe the battery is just fine. Is the charging connector replaceble ?
I need the answer to this problem as well !! someone help ! The micro usb port on the motherboard doesn't look like it can be desoldered like other devices .
Same here, my son uses my old developer edition.
I bought a replacement battery but I noticed that don't include the NFC antenna, what would you recommend? I'm not sure if I could unstick the one that have my old battery. Also what would happen if I don't connect that antenna?
jspsaucedo - 답글
how for all parties ? I have only the motherboard
If I have a issue with WI-FI and bluetooth connectivity (hardware component failure). Can I replace only Qualcomm WCN3680 802.11ac IC.?
or I have to replace whole motherboard?
Where is the Wireless Antenna located on the Moto X. I have replaced the lower antenna assembly, but that does not seem to fix my Wireless Antenna problem. My phone's wifi antenna is not working. it tries to connect, but then fails and keeps toggling between Connecting... and Saved connection.
Where is the Wifi Antenna located? What part needs to be replaced?
Ken Parker - 답글
Hey Ken. Ever figure out the answer to this? I'm having the same problem.
Hi, anybody knows what is the number of the wifi ic module for MOTO X PLAY XT1563?
Hi, anybody knows what is the model number of the WIFI IC module for MOTO X PLAY XT1563?
Is this possible in this model to turn on FM radio by rooting or the model's antenna is grounded ??
