주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Motorola i450 Boost Mobile 수리는 저희 서비스 설명서를 사용하십시오.
  1. Motorola i450 Boost Mobile Teardown, Antenna: 1 단계, 이미지 1/3 Motorola i450 Boost Mobile Teardown, Antenna: 1 단계, 이미지 2/3 Motorola i450 Boost Mobile Teardown, Antenna: 1 단계, 이미지 3/3
    • Place the phone on a flat surface with the front facing down and the antenna fully extended.
    • Use a spudger to remove the circular rubber cover from the base of the antenna.
    • Remove the 3.2 mm Torx T5 screw located under the rubber cover.
  2. Motorola i450 Boost Mobile Teardown: 2 단계, 이미지 1/3 Motorola i450 Boost Mobile Teardown: 2 단계, 이미지 2/3 Motorola i450 Boost Mobile Teardown: 2 단계, 이미지 3/3
    • Remove the antenna by grasping from the white plastic piece just below the antenna and pulling away from the phone.
    • Do not grasp the black antenna piece to pull it out. Doing so may damage it.
  3. Motorola i450 Boost Mobile Teardown, Back Cover: 3 단계, 이미지 1/3 Motorola i450 Boost Mobile Teardown, Back Cover: 3 단계, 이미지 2/3 Motorola i450 Boost Mobile Teardown, Back Cover: 3 단계, 이미지 3/3
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  4. Motorola i450 Boost Mobile Teardown, Battery: 4 단계, 이미지 1/3 Motorola i450 Boost Mobile Teardown, Battery: 4 단계, 이미지 2/3 Motorola i450 Boost Mobile Teardown, Battery: 4 단계, 이미지 3/3
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  5. Motorola i450 Boost Mobile Teardown, SIM Card: 5 단계, 이미지 1/2 Motorola i450 Boost Mobile Teardown, SIM Card: 5 단계, 이미지 2/2
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  6. Motorola i450 Boost Mobile Teardown: 6 단계, 이미지 1/3 Motorola i450 Boost Mobile Teardown: 6 단계, 이미지 2/3 Motorola i450 Boost Mobile Teardown: 6 단계, 이미지 3/3
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  7. Motorola i450 Boost Mobile Teardown, Circuit Board: 7 단계, 이미지 1/1
    • Extend the antenna.
  8. Motorola i450 Boost Mobile Teardown: 8 단계, 이미지 1/1
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  9. Motorola i450 Boost Mobile Teardown: 9 단계, 이미지 1/3 Motorola i450 Boost Mobile Teardown: 9 단계, 이미지 2/3 Motorola i450 Boost Mobile Teardown: 9 단계, 이미지 3/3
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  10. Motorola i450 Boost Mobile Teardown, Keypad: 10 단계, 이미지 1/3 Motorola i450 Boost Mobile Teardown, Keypad: 10 단계, 이미지 2/3 Motorola i450 Boost Mobile Teardown, Keypad: 10 단계, 이미지 3/3
    • Gently lift the end of the circuit board farthest from the phone hinge.
    • The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
    • Grasp the keypad at the bottom of the phone, raise it, and pull it away.
  11. Motorola i450 Boost Mobile Teardown, Motorola i450 Boost Mobile Teardown: 11 단계, 이미지 1/1
    • Exploded view of all phone components.
Nathan Heavner
회원 가입일: 10/22/12
3 평판
안내서 1개 작성함
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 회원
CLEM-BENSON-F12S15G2
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 1,256
