주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. My First Sony Cassette-Corder TCM-4500 수리는 저희 서비스 설명서를 사용하십시오.
  1. My First Sony Cassette-Corder Teardown, My First Sony Cassette-Corder Teardown: 1 단계, 이미지 1/3 My First Sony Cassette-Corder Teardown, My First Sony Cassette-Corder Teardown: 1 단계, 이미지 2/3 My First Sony Cassette-Corder Teardown, My First Sony Cassette-Corder Teardown: 1 단계, 이미지 3/3
    • Here we have a 'my first Sony' cassette player with a microphone
    • It can even take a second microphone, sold seperately of course
    • Main microphone plug
    • Secondary Microphone plug
  2. My First Sony Cassette-Corder Teardown: 2 단계, 이미지 1/3 My First Sony Cassette-Corder Teardown: 2 단계, 이미지 2/3 My First Sony Cassette-Corder Teardown: 2 단계, 이미지 3/3
    • This model uses four C-cell batteries, these have been in here since I was 10, hmmm... wonder if there's any juice left?
    • Time to take the batteries out
    • Push down at one end of each row of batteries towards the spring
    • With the tension released pull out on the battery until it comes out
    • Repeat until all four are removed
    • Thumbs up to Sony for providing nice visual instructions for those kiddies
  3. My First Sony Cassette-Corder Teardown: 3 단계, 이미지 1/2 My First Sony Cassette-Corder Teardown: 3 단계, 이미지 2/2
    • To remove the red back cover you need to remove six screws placed around the border of the cover. Note! The bottom 2 screws are longer than the other 4. These 2 are 35mm long whilst the other 4 are only 30mm long. Don't mix them up !
    • And voilà! Now we have a nice view of all the internal components
  4. My First Sony Cassette-Corder Teardown: 4 단계, 이미지 1/2 My First Sony Cassette-Corder Teardown: 4 단계, 이미지 2/2
    • Remove one screw to take off the rear part of the carrying handle
    • We also gain access to the rubber microphone holder
  5. My First Sony Cassette-Corder Teardown: 5 단계, 이미지 1/3 My First Sony Cassette-Corder Teardown: 5 단계, 이미지 2/3 My First Sony Cassette-Corder Teardown: 5 단계, 이미지 3/3
    • To remove the speaker first you'll need to get some slack on the wire, do this by pulling it out of a plastic holder thing
    • Proceed to to lift up the blue chassis and remove the four screws holding the speaker down
    • These screws also hold the yellow speaker grill to the front
  6. My First Sony Cassette-Corder Teardown: 6 단계, 이미지 1/1
    • It was a bit of a fight but I was able to pull the blue chassis out of the front piece of the red case
    • There were no fasteners holding them together
  7. My First Sony Cassette-Corder Teardown: 7 단계, 이미지 1/3 My First Sony Cassette-Corder Teardown: 7 단계, 이미지 2/3 My First Sony Cassette-Corder Teardown: 7 단계, 이미지 3/3
    • Take out three screws to remove the main circuit board
    • Then unplug four sockets attached to the circuit board
    • And here we have the only circuit board in this device, don't see any big processors on it, I guess I can't turn it into a super computer :(
  8. My First Sony Cassette-Corder Teardown: 8 단계, 이미지 1/2 My First Sony Cassette-Corder Teardown: 8 단계, 이미지 2/2
    • After unplugging the circuit board we can completely remove the speaker
    • It packs a whopping 3 1/2 inch speaker
  9. My First Sony Cassette-Corder Teardown: 9 단계, 이미지 1/3 My First Sony Cassette-Corder Teardown: 9 단계, 이미지 2/3 My First Sony Cassette-Corder Teardown: 9 단계, 이미지 3/3
    • Remove four screws to loosen the tape drive chassis
    • Then pull up and back to take the chassis out
    • With the tape drive chassis on its own we can look at Sony's weird button system, we also have the blue chassis with no components on it
  10. My First Sony Cassette-Corder Teardown: 10 단계, 이미지 1/1
    • Take out two screws to remove the tape reader/writer
  11. My First Sony Cassette-Corder Teardown: 11 단계, 이미지 1/3 My First Sony Cassette-Corder Teardown: 11 단계, 이미지 2/3 My First Sony Cassette-Corder Teardown: 11 단계, 이미지 3/3
    • To take the microphone apart just pull very hard on the red handle and it will come out, its held on by two tabs
    • Take off the yellow cover by wedging a flathead screwdriver in the crack and prying it off
    • Now we can look at a little microphone, and surprisingly it even has its own windscreen
  12. My First Sony Cassette-Corder Teardown: 12 단계, 이미지 1/1
    • So here we have it all disassembled, and THERE WERE NO 'WARRANTY VOID' STICKERS ANYWHERE!!!
Harry333
회원 가입일: 10/22/09
14 평판
안내서 1개 작성함
댓글 2개
Do you know where I can find belts for this device? I need both belts new.
Florian Neiss - 답글
Try to look if you can replace it with kind of mixed belt pack : https://www.ebay.fr/itm/Universel-50-Mix...
François Opter -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 24
전체 시간: 10,483
