주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Netgear Router 수리는 저희 서비스 설명서를 사용하십시오.
  1. Netgear G54 Wireless Router Teardown, NetGear G54 Wireless Router: 1 단계, 이미지 1/3 Netgear G54 Wireless Router Teardown, NetGear G54 Wireless Router: 1 단계, 이미지 2/3 Netgear G54 Wireless Router Teardown, NetGear G54 Wireless Router: 1 단계, 이미지 3/3
    • Flip the Net Gear wireless Router over remove four rubber tabs .
    • Place them to the side
  2. Netgear G54 Wireless Router Teardown, Removing  the rubber tabs: 2 단계, 이미지 1/1
    • There four screws that need to be removed.
  3. Netgear G54 Wireless Router Teardown, Removing the four bottom screws: 3 단계, 이미지 1/3 Netgear G54 Wireless Router Teardown, Removing the four bottom screws: 3 단계, 이미지 2/3 Netgear G54 Wireless Router Teardown, Removing the four bottom screws: 3 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove the four screws.
    • Place them aside
  4. Netgear G54 Wireless Router Teardown, Removing the case: 4 단계, 이미지 1/3 Netgear G54 Wireless Router Teardown, Removing the case: 4 단계, 이미지 2/3 Netgear G54 Wireless Router Teardown, Removing the case: 4 단계, 이미지 3/3
    • Removing the bottom top facing up .
    • Put it to the side.
  5. Netgear G54 Wireless Router Teardown, Removing  the front clear plastic: 5 단계, 이미지 1/2 Netgear G54 Wireless Router Teardown, Removing  the front clear plastic: 5 단계, 이미지 2/2
    • Use a spudger on the edge of the clear hard plastic around the outer casing.
    • Use a spudger on the edge to push up the plastic casing.
    • Once the clear plastic casing is removed, place it to the side.
  6. Netgear G54 Wireless Router Teardown, Removing the motherboard: 6 단계, 이미지 1/3 Netgear G54 Wireless Router Teardown, Removing the motherboard: 6 단계, 이미지 2/3 Netgear G54 Wireless Router Teardown, Removing the motherboard: 6 단계, 이미지 3/3
    • Remove the motherboard with bottom case. Then you are done.
  7. Netgear G54 Wireless Router Teardown: 7 단계, 이미지 1/1
    • After remove the motherboard . The top cases of the Router.
kempc8
회원 가입일: 11/22/13
899 평판
안내서 7개 작성하였습니다
K and K Fixit K and K Fixit 회원
Business
1 회원
안내서 11개 작성하였습니다
댓글 2개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 2,910
