분해도
해당 분해도는 수리 안내서가 아닙니다. Nikko La Nera Junior 수리는 저희 서비스 설명서를 사용하십시오.
The Car, the Remote Control and a Phillips screwdriver.
Let's start!
Remove this screw.
The rear wing
Unscrew this black screws
Remove the wing
The Exhausts
Remove these screws
Remove the exhausts
The Rear Cover
The "tubolar" body
Flip the car
Remove these screws.
Remove the body
The seat
Remove these screws (one of these is back of the seat)
Remove the seat.
The antenna
Remove this screw
Raise the circuit board
Remove the antenna
The "engine"
Remove the gears cover
Remove the engine block
Remove the gear and his hinge
Remove this piece of plastic
The Engine!
Remove the wheels from the car
The Steering Mechanism
Remove the cover
Lift the wheels
Remove the steering bar...
...the two screws...
...and the cover.
Remove the first "gear"...
...and the second.
Remove the steering motor
Remove the plastic cover
Be careful!
Remove this piece
Remove the second piece...
...and the spring.
Congratulations! The car is torn down!
Let's tear down the remote!
Remove the screw in the PCB
Remove the screw in the piece of plastic at the end of the antenna
Remove the plastic piece around the beginning of the antenna
Carefully de-route the antenna from the PCB
Detach the two parts of eat key.
Congratulations! You've ended the teardown!
다른 기여자 3명과 함께
회원 가입일: 06/12/11
306 평판
안내서 2개 작성하였습니다
배지: 8
배지 +5개 더
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 1,789
