분해도
A teardown of the Nikon Coolpix 3500.
해당 분해도는 수리 안내서가 아닙니다. Nikon Coolpix 3500 수리는 저희 서비스 설명서를 사용하십시오.
Remove the battery cover.
Remove the battery.
Remove two 4.5 mm screws next to the battery slot.
Remove one 3 mm screw above the CF memory card slot.
Remove one 4.5 mm screw next to the CF memory card slot.
Remove two 4.5 mm screws from inside the battery slot.
Remove two 5 mm screws from the opposite end of the battery slot.
Remove the plastic cap and the 5 mm screw underneath.
Remove the five 3.5 mm screws from the bottom of the camera.
Gently pry off the grey faceplate.
Do not pull hard; there are two wires connecting the faceplate to the motherboard.
Use a spudger to disconnect the white-capped wire at the bottom of the camera.
Use a spudger to disconnect the orange-capped wire at the bottom of the camera and set the faceplate aside.
Disconnect the grey-capped wires from the motherboard.
Disconnect the blue wire attached to the green chip from the center of the motherboard.
Remove the 3.5 mm screw from the motherboard next to the rotating lens.
Flip the motherboard and lens over to access the three wires on the back that connect to the LED screen.
Disconnect the blue wire connecting the motherboard to the LED screen.
Disconnect the orange wire using a spudger while pushing out horizontally.
Disconnect the red capped wire from the motherboard.
Lift the motherboard and lens (still connected) out of the back case.
Lift up on the black covering and remove the orange wire connecting the lens to the motherboard.
Remove the 2.5 mm screw next to the red capped wire.
Remove the two 3.4 mm screws on the back of the directional buttons.
Remove the two 4.4 mm screws in the metal plate across from the orange wire.
Gently lift the LED screen out of the remaining casing and set it aside.
Be careful not to let the rubber backing of the buttons fall out of place.
다른 기여자 10명과 함께
회원 가입일: 04/19/10
183 평판
안내서 6개 작성하였습니다
배지: 6
배지 +3개 더
CPSU-GARNER-S10S30G38
5 회원들
안내서 11개 작성하였습니다
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 7,789
