A teardown of the Nikon Coolpix 3500.
해당 분해도는 수리 안내서가 아닙니다. Nikon Coolpix 3500 수리는 저희 서비스 설명서를 사용하십시오.
Remove two 4.5 mm screws next to the battery slot.
Remove one 3 mm screw above the CF memory card slot.
Remove one 4.5 mm screw next to the CF memory card slot.
Remove the five 3.5 mm screws from the bottom of the camera.
Gently pry off the grey faceplate.
Do not pull hard; there are two wires connecting the faceplate to the motherboard.
Disconnect the blue wire connecting the motherboard to the LED screen.
Disconnect the orange wire using a spudger while pushing out horizontally.
Disconnect the red capped wire from the motherboard.
Lift the motherboard and lens (still connected) out of the back case.
Remove the 2.5 mm screw next to the red capped wire.
Remove the two 3.4 mm screws on the back of the directional buttons.
Remove the two 4.4 mm screws in the metal plate across from the orange wire.
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
미리보기
