주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
  1. Nintendo DS Lite Teardown, Part  Seperartion: 1 단계, 이미지 1/1
    • Your first step would be to unscrew all all screws on the back and take the case off. You take the case off by placing a spudger on the line edges , and then place it inward, forcing it to separate the two parts.
  2. Nintendo DS Lite Teardown, WI-FI board: 2 단계, 이미지 1/1
    • You first remove the gabbles by gently pulling them and do the same for the WI-FI board
  3. Nintendo DS Lite Teardown, Screen Removal: 3 단계, 이미지 1/1
    • You take the mother board off by flipping the upside-down and the screen should pop right off.
  4. Nintendo DS Lite Teardown: 4 단계, 이미지 1/1
    • Unscrew and gently slide wires through frame
  5. Nintendo DS Lite Teardown, Final Look: 5 단계, 이미지 1/1
    • The DS should look like this and to put the DS back together simply follow steps back wards.
Isabella Sandoval
회원 가입일: 11/06/16
182 평판
안내서 1개 작성함
댓글 한 개
Don’t like this guide. Only a few steps. Tear downs usually have 50+. Add more and in detail.
Bob - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,930
