주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Nintendo GameCube Controller 수리는 저희 서비스 설명서를 사용하십시오.
  1. Nintendo GameCube Controller (Official) Teardown, Removing the back: 1 단계, 이미지 1/2 Nintendo GameCube Controller (Official) Teardown, Removing the back: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Locate and remove six (6) tri-point screws.
    • If you are unable to get a tri-point screwdriver into the hole (specifically the two in the bottom of the grips), a very small tip flathead may be used. Be very slow and cautious not to strip out the screws.
    • Gently pry the two halves of the controller apart using plastic cards or tools.
  2. Nintendo GameCube Controller (Official) Teardown, Disassembling the triggers: 2 단계, 이미지 1/3 Nintendo GameCube Controller (Official) Teardown, Disassembling the triggers: 2 단계, 이미지 2/3 Nintendo GameCube Controller (Official) Teardown, Disassembling the triggers: 2 단계, 이미지 3/3
    • Remove four (4) phillips head screws from the interior trigger guards. Pull the trigger guards straight out to access the interior triggers.
    • The screws are interchangeable, but the guards are not.
    • Push up on the trigger base and pull it up and out of the slot it's sitting in. Pull the trigger assembly down and out of the case back. Left side shown, right side similar.
    • The trigger is pushed up by a spring which will send your pieces flying if not restrained.
    • Separate the trigger base from the trigger itself by popping the retention bar out of the bottom of the trigger (purple circle)
    • A flathead screwdriver may be used to gently pry the bar down. Do not bend the bar or break the plastic.
  3. Nintendo GameCube Controller (Official) Teardown, Removing the Circuit Board: 3 단계, 이미지 1/3 Nintendo GameCube Controller (Official) Teardown, Removing the Circuit Board: 3 단계, 이미지 2/3 Nintendo GameCube Controller (Official) Teardown, Removing the Circuit Board: 3 단계, 이미지 3/3
    • Buttons and button pads will fall out in the next steps.
    • Gently pull the circuit board up and out of the front case and set aside.
    • There's nothing holding either the pads to your board or the buttons into your front case, so take a moment to make sure you didn't drop any.
    • Remove any buttons you need from the front case. The Z button is the only one of note; there is a metal lever that sits in a groove and a post on the back side of it that sits in a hole to align the trigger.
  4. Nintendo GameCube Controller (Official) Teardown, Circuit Board Disassembly: 4 단계, 이미지 1/3 Nintendo GameCube Controller (Official) Teardown, Circuit Board Disassembly: 4 단계, 이미지 2/3 Nintendo GameCube Controller (Official) Teardown, Circuit Board Disassembly: 4 단계, 이미지 3/3
    • Gently pull the analog stick, C-Pad stick, and the pads for the D-Pad and face buttons.
    • Most everything else in here can get a nice soak in mild detergent and water, but the board doesn't want soap or water. A soft toothbrush, Q-tips, and alcohol got her looking much better.
    • Reassemble is opposite of disassembly. Most pieces only fit one way.
  5. Nintendo GameCube Controller (Official) Teardown: 5 단계, 이미지 1/1
    • Full IC Identification:
    • You may need to enlarge it to view the text.
Skeletwing
회원 가입일: 11/18/18
127 평판
안내서 1개 작성함
댓글 한 개
i cannot find any replacement screws for the controller online. at all. please any equivalent screws if not oem? for the shell not internals.
samm07 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 67
30일 전: 363
전체 시간: 24,972
