주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Nintendo GameCube Controller 수리는 자사의 서비스 설명서를 사용하세요.
  1. Nintendo GameCube Controller Teardown, Separating the Separate Halves:: 1 단계, 이미지 2개 중 1개 Nintendo GameCube Controller Teardown, Separating the Separate Halves:: 1 단계, 이미지 2개 중 2개
    • Remove the six phillips head screws from the underside of the controller.
    • After these screws are removed, you can separate the bottom from the top of the controller.
  2. Nintendo GameCube Controller Teardown, Removing the Control Panel and Buttons:: 2 단계, 이미지 2개 중 1개 Nintendo GameCube Controller Teardown, Removing the Control Panel and Buttons:: 2 단계, 이미지 2개 중 2개
    • After removing the back of the controller, you can lift the circuit board out of the plastic shell.
    • With the circuit board removed, you can access the main buttons and remove them if desired.
  3. Nintendo GameCube Controller Teardown, Removing the Remotes Bumpers:: 3 단계, 이미지 2개 중 1개 Nintendo GameCube Controller Teardown, Removing the Remotes Bumpers:: 3 단계, 이미지 2개 중 2개
    • To remove the left and right bumpers from the bottom of the controller, pull up on the square base that keeps the button in place and then pull the button through the shell.
  4. Nintendo GameCube Controller Teardown, Pieces of the Controller:: 4 단계, 이미지 1개 중 1개
    • These are the parts that should come out of the remote; not regarding the control panel.
  5. Nintendo GameCube Controller Teardown, Removing the C-Stick:: 5 단계, 이미지 2개 중 1개 Nintendo GameCube Controller Teardown, Removing the C-Stick:: 5 단계, 이미지 2개 중 2개
    • Once the control panel is removed from the controller the c-stick can be easily, but carefully, removed.
작성자
2다른 기여자 명과 함께
Pete Moreno
회원 가입일: 06/02/15
154 평판
안내서 1개를 작성함
댓글 5개
So uh... This isn't an official GameCube controller. The official ones have Nintendo branding above the start button as well as a differently colored mainboard and tri-wing screws instead of Phillips. There are other slight differences in some components too. Do you mind someone else redoing this teardown with an official controller?
sigoshi - 답글
That would be awesome! Please do! =)
Sam Goldheart -
i will gladly do so in the next few weeks
ZeldaAwesome -
so is this with the official controllers now or has it still not been updated yet?
thanhan287 - 답글
This is pretty close to the official controller. I’ve submitted a separate guide for the official controller teardown.
Skeletwing -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 45
전체 시간: 16,950
