해당 분해도에 사용된 도구
해당 분해도는 수리 안내서가 아닙니다. Nintendo WaveBird Wireless Controller 수리는 저희 서비스 설명서를 사용하십시오.
  1. This is the connector side of the WaveBird receiver. Remove two tri-wing screws, and separate the black and gray halves of the receiver.
    • This is the connector side of the WaveBird receiver.
    • Remove two tri-wing screws, and separate the black and gray halves of the receiver.
  2. Remove four tri-wing screws to remove the connector from the housing. Remove four tri-wing screws to remove the connector from the housing.
    • Remove four tri-wing screws to remove the connector from the housing.
  3. Insert wisdom here. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  4. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Red: 3.43V logic supply (pin 1 on cable)
    • Red: 3.43V logic supply (pin 1 on cable)
    • Brown: Ground (pin 3 on cable)
    • Green: Data (pin 2 on cable, recessed by 2mm into connector)
    • Violet: Shield (pin 4 on cable)
  6. The PCB has a metal RF shield that protects the radio from interference from the game console; this extends the useful range of the controller. One half of the shield is held on with friction clips; the other half must be desoldered.
    • The PCB has a metal RF shield that protects the radio from interference from the game console; this extends the useful range of the controller.
    • One half of the shield is held on with friction clips; the other half must be desoldered.
  7. The IC is a custom (or relabeled) Nintendo chip marked "WCRX-DOL / T2.7488K1".  ("Wireless Controller Receiver - Dolphin").  It is presumably a microcontroller that decodes signals from the radio and sends them to the console.
    • The IC is a custom (or relabeled) Nintendo chip marked "WCRX-DOL / T2.7488K1". ("Wireless Controller Receiver - Dolphin"). It is presumably a microcontroller that decodes signals from the radio and sends them to the console.
    • This 4-pin connector goes to the joypad connector on the GameCube.
    • Desolder these four points to remove the shield and expose the radio on the other side.
  8. The bottom side has all the RF circuitry -- the chip is a Nintendo chip marked "WR-DOL / H2102 / CG2710 / 02", presumably the radio.
    • The bottom side has all the RF circuitry -- the chip is a Nintendo chip marked "WR-DOL / H2102 / CG2710 / 02", presumably the radio.
    • EPCOS X6882 custom bandpass filter
    • Trim-pot for adjustment at the factory -- could be a frequency tweak or gain adjustment.
    • The rotary switch allows the user to choose a frequency to avoid interference with other devices.
    • The antenna is mounted directly on the PCB, inside the device.
bushing
회원 가입일: 2010년 04월 23일
9,332 평판
안내서 13개 작성하였습니다
Hello. I have 2 receivers that only have three pins. Just below the Data pin there is nothing there...not as your pictures show. I bought a wavebird on ebay and it wont work. How can both of my receivers be missing a pin? I treat them like gold because I know these are not manufactured by Nintendo anymore. So it looks like the 2mm into connectors are missing. What? How?
cllonyx - 답글
The Wavebird receiver only needs 3.3volts, data and ground to operate so that's why there is only 3 pins.
If you gave more details on whats happening it would be much easier to diagnose the problem.
Ivan -
My receiver is dead I think. The controller is perfectly fine but the receiver light won't even come on. Any suggestions how to resurrect this receiver?
Stan Roy - 답글
Hello Stan!
I have opened the receiver and scratched the antena (in step 7) with a screwdriver because I saw it was very dark and some black dust came off. Now it works like new.
I also have found that some receivers won't work on the first port if they're on high frequencies and have no trouble if you dial down to the first five positions. I have no idea why but it works.
All the best!!
Fer -
So i was playing some games with my wavebird controller and went the morning after that for a couple of day on vacation. As soon as i came back i turned my gamecube on, but the Wavebird isnt working anymore. Tried out all the channels and ports, but the Receiver light wont light up anymore when i press a button. How do i fix this?
Fer mentioned earlier i need to scratch around my antenna in step 7. Does this really work?
Daniel6254 - 답글
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 109
전체 시간: 12,493
