주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Nintendo Wii Remote 수리는 저희 서비스 설명서를 사용하십시오.
  1. Nyko Wand Teardown, Removing battery cover and back plate: 1 단계, 이미지 1/3 Nyko Wand Teardown, Removing battery cover and back plate: 1 단계, 이미지 2/3 Nyko Wand Teardown, Removing battery cover and back plate: 1 단계, 이미지 3/3
    • First flip controller so that the back plate faces you
    • Remove the battery cover by pushing up on the bottom plate
  2. Nyko Wand Teardown: 2 단계, 이미지 1/2 Nyko Wand Teardown: 2 단계, 이미지 2/2
    • Remove both batteries if their are any inside the remote .
    • To remove them press down on the positive end then pull to take out
  3. Nyko Wand Teardown: 3 단계, 이미지 1/2 Nyko Wand Teardown: 3 단계, 이미지 2/2
    • Using the tri-point Y1 Screw driver remove the two center screws by turning counter clock wise
    • Repeat process for bottom two
  4. Nyko Wand Teardown: 4 단계, 이미지 1/3 Nyko Wand Teardown: 4 단계, 이미지 2/3 Nyko Wand Teardown: 4 단계, 이미지 3/3
    • To fully take off the back piece you will have to use your flat head screw driver and gently go along the edge and unclip it.
    • Gently pull out the whole circuit board ( be careful you may break or rip a wire if you pull to hard )
    • {CAUTION :WATCH OUT FOR SMALL PARTS}
  5. Nyko Wand Teardown: 5 단계, 이미지 1/3 Nyko Wand Teardown: 5 단계, 이미지 2/3 Nyko Wand Teardown: 5 단계, 이미지 3/3
    • To remove the buttons you will simply have to take off the grey silicon cover.
    • To remove the small speaker you can simply pull up .
    • CAUTION : FOR SMALLER BUTTONS LIKE THE VOLUME ONES .
  6. Nyko Wand Teardown: 6 단계, 이미지 1/2 Nyko Wand Teardown: 6 단계, 이미지 2/2
    • Gently pry the buttons upwards ,removing the buttons from its holding slot.
    • CAUTION : WATCH OUT FOR SMALL BUTTONS !
    • IF YOU WANT TO REBUILD IT FOLLOW STEPS 1-7 BACKWORDS.
Demian De La Vega
회원 가입일: 04/17/19
143 평판
안내서 1개 작성함
댓글 한 개
good¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
RIGO NOLASCO - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 26
전체 시간: 2,404
