Disassembling the remote requires removing screws under the batteries.Removing anything inside will require caution and time .
해당 분해도는 수리 안내서가 아닙니다. Nintendo Wii Remote 수리는 저희 서비스 설명서를 사용하십시오.
To fully take off the back piece you will have to use your flat head screw driver and gently go along the edge and unclip it.
Gently pull out the whole circuit board ( be careful you may break or rip a wire if you pull to hard )
{CAUTION :WATCH OUT FOR SMALL PARTS}
To remove the buttons you will simply have to take off the grey silicon cover.
To remove the small speaker you can simply pull up .
CAUTION : FOR SMALLER BUTTONS LIKE THE VOLUME ONES .
Gently pry the buttons upwards ,removing the buttons from its holding slot.
CAUTION : WATCH OUT FOR SMALL BUTTONS !
IF YOU WANT TO REBUILD IT FOLLOW STEPS 1-7 BACKWORDS.
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
미리보기
