메인 콘텐츠로 스킵하기
해당 분해도에 사용된 도구
해당 분해도는 수리 안내서가 아닙니다. Nokia 2605 수리는 저희 서비스 설명서를 사용하십시오.
  1. Red arrows indicate which screws must be removed in order to get to the motherboard.
    • Red arrows indicate which screws must be removed in order to get to the motherboard.
  2. Take T5 torx and remove all 3 screws.
    • Take T5 torx and remove all 3 screws.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Wedge a flat head in between the back and phone exterior starting at the bottom corners.
    • Wedge a flat head in between the back and phone exterior starting at the bottom corners.
    • As you move toward the top, remove the camera and volume buttons.
  5. Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip). Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip).
    • Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip).
Dorsa
회원 가입일: 2013년 11월 07일
143 평판
안내서 1개 작성함
University of Maryland, Team 1-7, Calloway Fall 2013 University of Maryland, Team 1-7, Calloway Fall 2013 회원
UMD-CALLOWAY-F13S1G7
3 회원들
안내서 1개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,025
