분해도
I'm going to open my old Nokia phone to have a look.But I only have very limited English writing skills and I hope you'll understand what I'm talking about.
해당 분해도는 수리 안내서가 아닙니다. Nokia 6108 수리는 저희 서비스 설명서를 사용하십시오.
Hello,I'm going to open my phone for some fun.
Be careful not to drop any screws or parts when you're opening your phone.This may render your phone not usuable.Open your phone at your own risk.
Remove the following parts.
Battery cover
Battery
SIM card
Remove two trox screws marked in figure 2.
Remove the front panel by pulling it or using an
I don't have a opening tool.So I used a flathead screw driver instead.
Be careful not the damage the number pad connector(highlighted in red).If you break it.You'll have to replace the entre front panel.
Remove 5 trox screws that are holding the screen and the touch pad.
After removing the touch pad and the screen.You can remove the logic board from the case.
The board seem don't want to leave its cozy home.
Let's start removing the parts under the logic board.
Parts need to be removed.
A motor
Charger connector
A speaker
Removing the EMI shield.Pry around the edge of the shield to remove it.
Nothing under the EMI shield.
I think we should stop here right now.There are pictures for all parts.
다른 기여자 3명과 함께
회원 가입일: 02/19/11
349 평판
안내서 1개 작성함
배지: 10
배지 +7개 더
i have same phone but it's keypad button's are not working.... can u help me that
Rohit Yadav - 2014년 3월 11일 답글
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 4,715
