주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Nokia 6108 수리는 저희 서비스 설명서를 사용하십시오.
  1. Nokia 6108 Teardown, Nokia 6108 Teardown: 1 단계, 이미지 1/1
    • Hello,I'm going to open my phone for some fun.
    • Be careful not to drop any screws or parts when you're opening your phone.This may render your phone not usuable.Open your phone at your own risk.
  2. Nokia 6108 Teardown: 2 단계, 이미지 1/2 Nokia 6108 Teardown: 2 단계, 이미지 2/2
    • Remove the following parts.
    • Battery cover
    • Battery
    • SIM card
    • Remove two trox screws marked in figure 2.
  3. Nokia 6108 Teardown: 3 단계, 이미지 1/2 Nokia 6108 Teardown: 3 단계, 이미지 2/2
    • Remove the front panel by pulling it or using an
    • I don't have a opening tool.So I used a flathead screw driver instead.
    • Be careful not the damage the number pad connector(highlighted in red).If you break it.You'll have to replace the entre front panel.
  4. Nokia 6108 Teardown: 4 단계, 이미지 1/2 Nokia 6108 Teardown: 4 단계, 이미지 2/2
    • Remove 5 trox screws that are holding the screen and the touch pad.
  5. Nokia 6108 Teardown: 5 단계, 이미지 1/2 Nokia 6108 Teardown: 5 단계, 이미지 2/2
    • After removing the touch pad and the screen.You can remove the logic board from the case.
    • The board seem don't want to leave its cozy home.
  6. Nokia 6108 Teardown: 6 단계, 이미지 1/1
    • Let's start removing the parts under the logic board.
    • Parts need to be removed.
    • A motor
    • Charger connector
    • A speaker
  7. Nokia 6108 Teardown: 7 단계, 이미지 1/1
    • Removing the EMI shield.Pry around the edge of the shield to remove it.
  8. Nokia 6108 Teardown: 8 단계, 이미지 1/2 Nokia 6108 Teardown: 8 단계, 이미지 2/2
    • Nothing under the EMI shield.
    • I think we should stop here right now.There are pictures for all parts.
Honam1021
회원 가입일: 02/19/11
349 평판
안내서 1개 작성함
댓글 한 개
i have same phone but it's keypad button's are not working.... can u help me that
Rohit Yadav - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 4,715
