주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Nokia Asha 200 수리는 저희 서비스 설명서를 사용하십시오.
  1. Nokia Asha 200 Teardown, Nokia Asha 200 Teardown: 1 단계, 이미지 1/1
    • Take the back cover off and remove the battery. (Not shown)
    • Remove the two screws located with red circles
  2. Nokia Asha 200 Teardown: 2 단계, 이미지 1/3 Nokia Asha 200 Teardown: 2 단계, 이미지 2/3 Nokia Asha 200 Teardown: 2 단계, 이미지 3/3
    • Insert spudger between the front/back case and lever untill you hear a click.
    • Slowly work your way around until the bottom end is separated. Then with the bottom end facing your body, try to pull the back case towards yourself.
    • Make sure not to loose Sim2 and Micro SD covers as they easily fall out. Also when re-assembling make sure they are pulled out otherwise you will have trouble putting things back together
  3. Nokia Asha 200 Teardown: 3 단계, 이미지 1/3 Nokia Asha 200 Teardown: 3 단계, 이미지 2/3 Nokia Asha 200 Teardown: 3 단계, 이미지 3/3
    • Remove the 4 screws marked with red circles
    • There are two clips now holding the circuit board in place. Maneuver the circuit board over one and then pull towards the released clip to release the opposite one.
  4. Nokia Asha 200 Teardown: 4 단계, 이미지 1/2 Nokia Asha 200 Teardown: 4 단계, 이미지 2/2
    • The lcd screen is held in by a steel bracket. This bracket is held in place by the clips marked with red squares. The easit way to release it is by levering the one on the right (as pictured) and the bracket should come off.
    • When re-assembling make sure the studs marked with blue circles line up properly.
    • Using a spudger disconnect the LCD cable.
  5. Nokia Asha 200 Teardown: 5 단계, 이미지 1/1
    • Congratulations you have successfully dis-assembled the phone. I hope you had as much fun tearing it apart as I did helping you along the way.
Joel
회원 가입일: 10/24/12
207 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 5,207
