소개
Alright, Palmer—you asked, and we answered. Last week we tore down the Oculus Rift CV1, and today we turn our heads to Constellation—Rift's counterpart IR camera. Did Oculus shoot for the stars like in their high-powered headset, or will their design decisions leave the Constellation virtually unrepairable? Only a teardown will tell.
Hungry for more? Feast your eyes on the latest teardowns and more by following us on Instagram, Twitter, or Facebook.
필요한 것
We don't know too much about the Constellation sensor itself, but here are some specs:
Infrared sensor
Sweet stand
Standard USB 3.0 cable
Let's try to smoke it out the other end. iOpener to full!
Hats off to the smallest suction cup we could find! With one good tug, the modestly adhered visible-light filter gives way to reveal the eye of the IR camera.
Because the Constellation sensor's job is to track LEDs that only give off infrared light, any other wavelength is just noise, making it harder for it to operate. This filter blocks out everything but IR, making it easier to pick out the LEDs.
Okay, we asked nicely twice, but the components still won't budge—time for some aggressive negotiations.
We shuck the (well-rotary-tooled) outer casing and find an inner shell secured with some fiercely-glued screws.
Whipping that away in short order, all that's left are the real guts of this sensor.
We're at the end of the line—let's take a peek at the silicon!
EtronTech eSP770U Webcam Controller
Nordic Semiconductor nRF51822 Bluetooth Smart and 2.4GHz proprietary SoC (also found in the Oculus Rift Headset)
Macronix MX25L1006E 1 Mb serial flash memory
STMicroelectronics BALF-NRF01D3 50 Ω Bluetooth balun
ON Semiconductor NC7SB3157L6X SPDT analog switch (likely)
ON Semiconductor NCP1529MUTBG adjustable 1 A DC-DC step down converter
ON Semiconductor ESD7004 4-ch. TVS diode array
Oculus Rift Constellation Sensor Repairability Score: 7 out of 10 (10 is easiest to repair)
Stand and visible light filter are removable and can be replaced if damaged.
All main components (motherboard, camera, lens, and filter) are discrete and modular, making repairs fairly low cost and straightforward.
The USB cable plugs directly into the motherboard and can be swapped out quickly.
Strong adhesive holds the visible light filter in place.
Stand hardware takes significant force to remove and is not obviously removable without instructions.
댓글 17개
But how do they assemble the thing together in the factory if you can't undo it without causing permanent damage?
Because it's meant to be bought again.
jvelez -
Glue. It's easy to glue things together. Hard to unglue them.
Ultrasonic welding, not glue.
Turns out you can pull it apart without cutting it open https://twitter.com/PalmerLuckey/status/...
karlww -
