주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Olympus Stylus 410 수리는 저희 서비스 설명서를 사용하십시오.
  1. Olympus Stylus 410 Teardown, Slider: 1 단계, 이미지 1/1
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Teardown: 2 단계, 이미지 1/1
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 Teardown: 3 단계, 이미지 1/1
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 Teardown: 4 단계, 이미지 1/1
    • The slider should now be free from the body of the camera.
  5. Olympus Stylus 410 Teardown, Outer Case: 5 단계, 이미지 1/3 Olympus Stylus 410 Teardown, Outer Case: 5 단계, 이미지 2/3 Olympus Stylus 410 Teardown, Outer Case: 5 단계, 이미지 3/3
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Olympus Stylus 410 Teardown: 6 단계, 이미지 1/2 Olympus Stylus 410 Teardown: 6 단계, 이미지 2/2
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  7. Olympus Stylus 410 Teardown: 7 단계, 이미지 1/2 Olympus Stylus 410 Teardown: 7 단계, 이미지 2/2
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  8. Olympus Stylus 410 Teardown: 8 단계, 이미지 1/2 Olympus Stylus 410 Teardown: 8 단계, 이미지 2/2
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  9. Olympus Stylus 410 Teardown: 9 단계, 이미지 1/3 Olympus Stylus 410 Teardown: 9 단계, 이미지 2/3 Olympus Stylus 410 Teardown: 9 단계, 이미지 3/3
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  10. Olympus Stylus 410 Teardown: 10 단계, 이미지 1/1
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  11. Olympus Stylus 410 Teardown: 11 단계, 이미지 1/2 Olympus Stylus 410 Teardown: 11 단계, 이미지 2/2
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  12. Olympus Stylus 410 Teardown, Flash: 12 단계, 이미지 1/2 Olympus Stylus 410 Teardown, Flash: 12 단계, 이미지 2/2
    • Locate the gray compartment covering the flash.
    • Position your flat head screw driver or small spudger underneath the tab that is keeping the gray cover on.
    • Gently lift the tab so the gray compartment becomes free.
  13. Olympus Stylus 410 Teardown: 13 단계, 이미지 1/3 Olympus Stylus 410 Teardown: 13 단계, 이미지 2/3 Olympus Stylus 410 Teardown: 13 단계, 이미지 3/3
    • Use the spudger around the perimeter of the gray compartment to detach it from the front case.
    • The gray compartment can now be removed from the flash unit.
    • The flash unit can now be removed, and a new one soldered back on.
  14. Olympus Stylus 410 Teardown, Battery Cover: 14 단계, 이미지 1/2 Olympus Stylus 410 Teardown, Battery Cover: 14 단계, 이미지 2/2
    • Open the battery cover and lift it up and off of back camera case.
  15. Olympus Stylus 410 Teardown: 15 단계, 이미지 1/3 Olympus Stylus 410 Teardown: 15 단계, 이미지 2/3 Olympus Stylus 410 Teardown: 15 단계, 이미지 3/3
    • Locate and unscrew the 2 screws with a #00 Phillips screwdriver.
    • Remove the black seal.
  16. Olympus Stylus 410 Teardown: 16 단계, 이미지 1/2 Olympus Stylus 410 Teardown: 16 단계, 이미지 2/2
    • Slide the metal piece off of the battery cover.
  17. Olympus Stylus 410 Teardown: 17 단계, 이미지 1/1
    • This is what the battery cover and back case look like completely disassembled.
  18. Olympus Stylus 410 Teardown, LCD Screen: 18 단계, 이미지 1/3 Olympus Stylus 410 Teardown, LCD Screen: 18 단계, 이미지 2/3 Olympus Stylus 410 Teardown, LCD Screen: 18 단계, 이미지 3/3
    • Remove the metal frame from the LCD screen using an opening tool.
  19. Olympus Stylus 410 Teardown: 19 단계, 이미지 1/3 Olympus Stylus 410 Teardown: 19 단계, 이미지 2/3 Olympus Stylus 410 Teardown: 19 단계, 이미지 3/3
    • Pry off the LCD screen from the top using an opening tool.
    • Do not pull the screen completely off because it will still be held on by two ribbon cables.
  20. Olympus Stylus 410 Teardown: 20 단계, 이미지 1/1
    • This is what the camera will look like now that the LCD screen is removed.
Rory Aronson
회원 가입일: 04/15/10
46 평판
안내서 6개 작성하였습니다
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 회원
CPSU-MANESS-S10S6G13
5 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 20
전체 시간: 4,826
