분해도
해당 분해도에 사용된 도구
동영상 지침
소개
This repair guide also shows how to repairing back cover/rear housing, vibration motor,charging port,loudspeaker, headphone jack and other components for OnePlus 3.
해당 분해도는 수리 안내서가 아닙니다. Oneplus 3 수리는 저희 서비스 설명서를 사용하십시오.
해당 안내서 퍼가기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
댓글 10개
Thanks for this video, is really helpful. One question where can i buy a used motherboard, in my motherboard is broken the rear camera, the rear camera and flash is not turning on.... for sure is a hardware issue ... ether i would need to fix the motherboard ether to replace with a used one .... no idea ....
Krisztian Adrian Barna - 답글
What is the thing on the back cover around the camera hole? Is it the NFC?
looping z - 답글
Yes that is the NFC sensor
Luke Boppart -
Do you know where to get it alone?
looping z - 답글
What do you mean?
James Dorn -
