필요한 것
The Ooma Telo's case is held together using small plastic clips around the top edge of the device.
Use a tool to slip between the seam and release the clips holding the top case on.
There are several clips fastening the top case on. Work your way around. Take your time. Once 3 sides are free, you can wiggle the top clips loose and remove the top case.
댓글 2개
Very, very helpful description with great photos. Does this telo support bluetooth out of the box or is that an add-on adapter?
Rev A00 does not include bluetooth and requires the add-on USB adapter.
