주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. iPhone 1st Generation Dock 수리는 저희 서비스 설명서를 사용하십시오.
  1. Original iPhone Dock Teardown, Original iPhone Dock Teardown: 1 단계, 이미지 1/3 Original iPhone Dock Teardown, Original iPhone Dock Teardown: 1 단계, 이미지 2/3 Original iPhone Dock Teardown, Original iPhone Dock Teardown: 1 단계, 이미지 3/3
    • The Original iPhone dock!
    • This dock only holds the original iPhone. It will not hold the iPhone 3G/3GS as it is wider and thicker.
  2. Original iPhone Dock Teardown: 2 단계, 이미지 1/3 Original iPhone Dock Teardown: 2 단계, 이미지 2/3 Original iPhone Dock Teardown: 2 단계, 이미지 3/3
    • Use a hair dryer or heat gun to weaken the adhesive holding the rubber foot to the dock.
    • Use a razor blade or flathead screwdriver to pull up part of the rubber foot.
    • While still hot, pull the rubber foot off the dock.
  3. Original iPhone Dock Teardown: 3 단계, 이미지 1/2 Original iPhone Dock Teardown: 3 단계, 이미지 2/2
    • Using a spudger or a flat head screwdriver, release the 6 clips holding the dock to the white plastic molding.
    • You will need to pry this out as the dock contains a weight that is stuck to the top casing with adhesive.
  4. Original iPhone Dock Teardown: 4 단계, 이미지 1/1
    • Heat up the adhesive that covers the three screws, so you can unscrew the screws that hold the weight in the base of the dock.
  5. Original iPhone Dock Teardown: 5 단계, 이미지 1/3 Original iPhone Dock Teardown: 5 단계, 이미지 2/3 Original iPhone Dock Teardown: 5 단계, 이미지 3/3
    • Remove the three screws holding the weight to the bottom plate.
  6. Original iPhone Dock Teardown: 6 단계, 이미지 1/1
    • The dock should look like this.
    • If not, go back and see what you did wrong.
  7. Original iPhone Dock Teardown: 7 단계, 이미지 1/1
    • Now remove the green logic board from the little plastic pegs on the bottom plate.
    • There is one peg under each black foam padding.
  8. Original iPhone Dock Teardown: 8 단계, 이미지 1/2 Original iPhone Dock Teardown: 8 단계, 이미지 2/2
    • The little white things are the pegs.
    • Gently use a spudger or flathead screwdriver to pry the logic board from the bottom plate.
    • Be very careful, as you could break the board doing this.
  9. Original iPhone Dock Teardown: 9 단계, 이미지 1/2 Original iPhone Dock Teardown: 9 단계, 이미지 2/2
    • Once done separating the logic board from the bottom plate, you should have 2 parts.
  10. Original iPhone Dock Teardown: 10 단계, 이미지 1/3 Original iPhone Dock Teardown: 10 단계, 이미지 2/3 Original iPhone Dock Teardown: 10 단계, 이미지 3/3
    • Disassembly is now complete. You will have five separate parts as shown in the picture.
  11. Original iPhone Dock Teardown: 11 단계, 이미지 1/3 Original iPhone Dock Teardown: 11 단계, 이미지 2/3 Original iPhone Dock Teardown: 11 단계, 이미지 3/3
    • Boom! Your done. It took me 32 minutes to figure this out with out damaging the dock.
    • I can do it in 3 minutes now that I've mastered the process.
    • If you don't replace the white top cover of the dock when reassembling, you will have a universal dock, that can also be used with an iPhone 3G/3GS.
    • It will also work with any iPod with a 30 pin connector.
Nicholas Ouimet
회원 가입일: 10/16/09
3,476 평판
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 40
전체 시간: 32,897
