주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
  1. Unscrew 8 side screws (flat 2.4mm or dedicated torx), then of the 4 rear screws (hex 1.5mm).
    • Unscrew 8 side screws (flat 2.4mm or dedicated torx), then of the 4 rear screws (hex 1.5mm).
  2. Remove the front of the phone, disconnecting the LED connector. Remove the front of the phone, disconnecting the LED connector. Remove the front of the phone, disconnecting the LED connector.
    • Remove the front of the phone, disconnecting the LED connector.
  3. Remove the 5 screws (Phillips #0) on the black support.
    • Remove the 5 screws (Phillips #0) on the black support.
    • Remove the black support.
  4. remove the 3 screws (Phillips #0) supporting the PCB.
    • remove the 3 screws (Phillips #0) supporting the PCB.
    • Disconnect the antenna on the right.
    • Disconnect the ZIF connector on the left.
    • Disconnect the ZIF connector at the top.
    • Disconnect the two connectors (battery) at the bottom.
  5. Withdraw the jammed SIM card. Withdraw the jammed SIM card.
    • Withdraw the jammed SIM card.
결론
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Steve Muller
회원 가입일: 2018년 05월 14일
178 평판
안내서 2개 작성하였습니다
Any idea how to remove the screen? Just Broke mine and cant find the phone for sale anywhere… and not screen with frame either, just the glass by itself…
hestbruden483 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 26
전체 시간: 370
