주요 콘텐츠로 건너뛰기
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Oura Ring 2 수리는 저희 서비스 설명서를 사용하십시오.
  1. Oura Ring 2 Teardown, Oura Ring 2 Teardown: 1 단계, 이미지 1/2 Oura Ring 2 Teardown, Oura Ring 2 Teardown: 1 단계, 이미지 2/2
    • This is primarily a video teardown, but intrepid iFixit community members have also submitted their own analyses. One reader in particular spent hours attempting to reverse engineer the Oura Ring 2 through the video, datasheets, and X-rays, and shared the following:
    • The two IR LED drivers should be the same type, one for each IR LED.
    • There's likely an operational amplifier for signal conditioning for the photo diode before the signal is sent to the microcontroller. (This is commonly done with these type of photo diode based health meters.)
    • If this is not a microcontroller, it could be a temperature sensor (not a thermistor).
    • A wireless charging IC, predicted based on its surrounding components and location.
    • And finally, a battery fuel gauge IC for probably determining battery health.
    • Based on all this, the second image shows the predicted block diagram.
댓글 6개
Wow, I didn’t even know smart rings existed. I also think that it’d be much easier to service if the titanium shell came off in two halves so nothing would have to be bent to service the electronics.
Ethan Zuo - 답글
Check out this review of the Oura Ring for a good overview - https://youtu.be/56RPyoNSrYY
jtisdale -
Is it possible for you to share SMD Markings on all the devices?
surya mishra - 답글
same request
Marsh Cai -
I found that the battery is from here: https://www.grepow.com/wearables/smart-r...
Liphyn Pan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 135
30일 전: 512
전체 시간: 41,725
