주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Palm IIIc 수리는 저희 서비스 설명서를 사용하십시오.
  1. Palm IIIc Teardown, Removing broken LCD screen: 1 단계, 이미지 1/1
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Palm IIIc Teardown: 2 단계, 이미지 1/1
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Palm IIIc Teardown, Remove the Front and Back Covers: 3 단계, 이미지 1/1
    • Using a spudger, carefully pry open the front and back covers along the side seam.
    • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
  4. Palm IIIc Teardown, Palm IIIc Teardown: 4 단계, 이미지 1/1
    • Unhook battery cable from the motherboard and remove the battery.
  5. Palm IIIc Teardown: 5 단계, 이미지 1/2 Palm IIIc Teardown: 5 단계, 이미지 2/2
    • Behind the motherboard remove the brown plastic clamp and remove the front screen cover.
  6. Palm IIIc Teardown: 6 단계, 이미지 1/2 Palm IIIc Teardown: 6 단계, 이미지 2/2
    • Unhook the blue and red screen cables.
  7. Palm IIIc Teardown: 7 단계, 이미지 1/3 Palm IIIc Teardown: 7 단계, 이미지 2/3 Palm IIIc Teardown: 7 단계, 이미지 3/3
    • Pop out the other two brown plastic clamps to release the screen and buttons.
  8. Palm IIIc Teardown: 8 단계, 이미지 1/1
    • The black clips on the edges of the device (see picture) must be unclipped to remove the motherboard.
    • Carefully remove the motherboard from the device, pulling the motherboard away from the clips.
  9. Palm IIIc Teardown: 9 단계, 이미지 1/1
    • Pull the screen out from the front.
  10. Palm IIIc Teardown: 10 단계, 이미지 1/1
    • The object is now fully disassembled.
Paulina Trujillo
회원 가입일: 04/07/11
265 평판
안내서 8개 작성하였습니다
Cal Poly, Team 20-69, Walters Spring 2011 Cal Poly, Team 20-69, Walters Spring 2011 회원
CPSU-WALTERS-S11S20G69
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 4,900
