주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
  1. Panini Iron Teardown, Side handles: 1 단계, 이미지 1/2 Panini Iron Teardown, Side handles: 1 단계, 이미지 2/2
    • Start by taking off the handle bar with the side handles by removing the screws on the side of the product.
  2. Panini Iron Teardown, Handle bar: 2 단계, 이미지 1/3 Panini Iron Teardown, Handle bar: 2 단계, 이미지 2/3 Panini Iron Teardown, Handle bar: 2 단계, 이미지 3/3
    • Next, seperate the handle bar from the side bars by unscrewing the screws on the inside of the handle bar.
  3. Panini Iron Teardown, Top cover: 3 단계, 이미지 1/2 Panini Iron Teardown, Top cover: 3 단계, 이미지 2/2
    • Now, take the top cover off. It should come off automatically, as the screws that held the side handles also held the top off the panini iron. Then, we can take of the metal top cover, by bending the pieces of iron that keep it together.
  4. Panini Iron Teardown, Upper heating plate: 4 단계, 이미지 1/3 Panini Iron Teardown, Upper heating plate: 4 단계, 이미지 2/3 Panini Iron Teardown, Upper heating plate: 4 단계, 이미지 3/3
    • After that, we can disconnect the wires and take the heat shield of the upper heating plate. The upper heating plate should be free now.
  5. Panini Iron Teardown, Bottom cover: 5 단계, 이미지 1/2 Panini Iron Teardown, Bottom cover: 5 단계, 이미지 2/2
    • Now that the top is entirely dismantled, we can continue with the bottom. Turn the product around and remove all the screws from the bottom cover (this is where you'll need the Tamper Proof Spanner). The cover of the electronics will fall off automatically.
  6. Panini Iron Teardown, Lower heating plate: 6 단계, 이미지 1/2 Panini Iron Teardown, Lower heating plate: 6 단계, 이미지 2/2
    • Next, the lower heating plate can be unscrewed. There are some wires attached that can be seen when lifting it up from the bottom cover.
  7. Panini Iron Teardown, Heat shields: 7 단계, 이미지 1/2 Panini Iron Teardown, Heat shields: 7 단계, 이미지 2/2
    • From the heating plate, we are now able to unscrew the heat shields.
    • Take the rest of the screws out of the inside of the bottom cover. This allows for the heat shield to come out.
    • Now grab the iOpener and melt the glue around the wiring of the LEDs. This allows for the LEDs to come out.
    • What’s left now is the wiring in the bottom and the last heat shield. The wiring can be disconnected outside of the cover. There is little plastic parts attached, that can be taken off, after which the wires can be disconnected.
  8. Panini Iron Teardown, Buttons: 11 단계, 이미지 1/2 Panini Iron Teardown, Buttons: 11 단계, 이미지 2/2
    • The last step is to take out the button and the covers of the neon indicator's. They are attached with snapfits, so can be pushed out.
Wouter Meijer
회원 가입일: 04/03/19
193 평판
안내서 1개 작성함
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 74
