주요 콘텐츠로 건너뛰기
해당 분해도에 사용된 도구
소개
How to open the device and what you'll find inside.
해당 분해도는 수리 안내서가 아닙니다. Philips Bluetooth adapter AEA2700 수리는 저희 서비스 설명서를 사용하십시오.
  1. here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter! here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter! here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter!
    • here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter!
  2. Remove 2 of the rubbers on the bottom side - you'll find 2 screws afterwards>> unscrew them ;) Remove 2 of the rubbers on the bottom side - you'll find 2 screws afterwards>> unscrew them ;)
    • Remove 2 of the rubbers on the bottom side - you'll find 2 screws afterwards>> unscrew them ;)
  3. now simply remove the top cover.
    • now simply remove the top cover.
  4. there's only one external component connected by cable: the NFC tag
    • there's only one external component connected by cable: the NFC tag
    • it's easily possible to remove the circuit
    • lift it on the front side of the device
    • and pull it this direction - it helps to push at the cinch connector!
  5. Front- and backview of the circuit Front- and backview of the circuit
    • Front- and backview of the circuit
  6. when reassembling take care to stick the NFC tag to the correct location in the cover
    • when reassembling take care to stick the NFC tag to the correct location in the cover
RFischer
회원 가입일: 2014년 12월 29일
265 평판
안내서 2개 작성하였습니다
댓글 한 개
Hello. Is there any way to use this device in a car through an adapter or modification?
Fabio Passarelli - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 3,700
