주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. PlayStation 2 Slimline 수리는 저희 서비스 설명서를 사용하십시오.
  1. PlayStation 2 Slimline Teardown, Let's get started: 1 단계, 이미지 1/1
    • Start with the console upside down.
  2. PlayStation 2 Slimline Teardown: 2 단계, 이미지 1/2 PlayStation 2 Slimline Teardown: 2 단계, 이미지 2/2
    • Remove the six screw covers and place on project mat.
    • Remove the six 4.0 mm screws on the base of the PS2. (Place on your project mat.)
  3. PlayStation 2 Slimline Teardown: 3 단계, 이미지 1/3 PlayStation 2 Slimline Teardown: 3 단계, 이미지 2/3 PlayStation 2 Slimline Teardown: 3 단계, 이미지 3/3
    • Separate the bottom of PS2 from the top. Place to the side.
  4. PlayStation 2 Slimline Teardown: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • ''This PS2 that I am tearing down has no clock battery!!"
    • Locate the clock battery. Take tweezers and gently disconnect from motherboard. (Place on project mat)
  5. PlayStation 2 Slimline Teardown: 5 단계, 이미지 1/2 PlayStation 2 Slimline Teardown: 5 단계, 이미지 2/2
    • IR sensor on the motherboard.
    • Gently use a spudger to release the blue/ white ribbon from motherboard, (Place IR sensor on project mat)
  6. PlayStation 2 Slimline Teardown: 6 단계, 이미지 1/3 PlayStation 2 Slimline Teardown: 6 단계, 이미지 2/3 PlayStation 2 Slimline Teardown: 6 단계, 이미지 3/3
    • Fan has red, black, and yellow wires under hold down tape. Remove the tape gently.
    • Release the connector gently from motherboard.
    • There three 1.6 mm screws around the base of the fan. Place both fan and screws on your project mat.
  7. PlayStation 2 Slimline Teardown: 7 단계, 이미지 1/3 PlayStation 2 Slimline Teardown: 7 단계, 이미지 2/3 PlayStation 2 Slimline Teardown: 7 단계, 이미지 3/3
    • Optical drive on the motherboard
    • There are four 4.0 mm screws holding the optical drive.
    • Remove the four screws and place the optical drive with it's screws on your project mat.
  8. PlayStation 2 Slimline Teardown: 8 단계, 이미지 1/1
    • There is a ribbon attached to the motherboard here. With your spudger, gently detach the ribbon from the motherboard's connection.
  9. PlayStation 2 Slimline Teardown: 9 단계, 이미지 1/1
    • Remove the single 2.4 mm screw located on the metal casing at the top of the motherboard.
  10. PlayStation 2 Slimline Teardown: 10 단계, 이미지 1/2 PlayStation 2 Slimline Teardown: 10 단계, 이미지 2/2
    • Gently lift the metal casing from the motherboard. Place it to the side.
  11. PlayStation 2 Slimline Teardown: 11 단계, 이미지 1/1
    • Flip the motherboard over and remove the five screws of the second metal casing.
    • Place screws on project mat and casing to the side,
  12. PlayStation 2 Slimline Teardown: 12 단계, 이미지 1/2 PlayStation 2 Slimline Teardown: 12 단계, 이미지 2/2
    • Motherboard of PS2
    • Thank you for reading through this PS2 tear down. I hope this was helpful,
kempc8
회원 가입일: 11/22/13
899 평판
안내서 7개 작성하였습니다
K and K Fixit K and K Fixit 회원
Business
1 회원
안내서 11개 작성하였습니다
댓글 2개
Easy there Cricket, kempc8 is (partly) right about the clock battery. There is no clock battery to disconnect in step 4, that is correct. But there is one in step 12 in a bracket, that is correct too. The reason kempc8 mentioned there is because there are other types of the PS2 slimline which do have a clock battery to remove in step 4 (seen in step 3 of this teardown)
So there is no need to call the teardown stupid, it’s well written imho.
DBX12 - 답글
This is strange, but I have PS2 and optical drive mount by 3, 4mm screws, and another one is small, like for motherboard. The screw is located in a right low corner of the optical drive.
alexspidermoscow - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 60
30일 전: 276
전체 시간: 21,046
