주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Pocket C.H.I.P. 수리는 자사의 서비스 설명서를 사용하세요.
  1. Pocket C.H.I.P. Teardown, Remove the CHIP: 1 단계, 이미지 2개 중 1개 Pocket C.H.I.P. Teardown, Remove the CHIP: 1 단계, 이미지 2개 중 2개
    • To start off, power off the computer, remove the CHIP on the back.
    • You shouldn't need any special tools for this, but it might be a little tight, so you might need to wiggle it a bit.
    • Be careful and apply even pressure so you don't bend the pins.
  2. Pocket C.H.I.P. Teardown, Screen Cover: 2 단계, 이미지 1개 중 1개
    • Then remove the front screen border.
    • There are four clips around either side for you to unclip.
  3. Pocket C.H.I.P. Teardown, Yummy Chips: 3 단계, 이미지 2개 중 1개 Pocket C.H.I.P. Teardown, Yummy Chips: 3 단계, 이미지 2개 중 2개
    • This is the main CHIP computer.
    • To access the rest of the computer, you need to remove the cover with a single Philips screw.
  4. Pocket C.H.I.P. Teardown, Remove the back: 4 단계, 이미지 3개 중 1개 Pocket C.H.I.P. Teardown, Remove the back: 4 단계, 이미지 3개 중 2개 Pocket C.H.I.P. Teardown, Remove the back: 4 단계, 이미지 3개 중 3개
    • Remove the clear back cover
    • There are four clips, two on the top, two on the bottom that should be unclipped to remove it.
  5. Pocket C.H.I.P. Teardown, Remove the battery: 5 단계, 이미지 3개 중 1개 Pocket C.H.I.P. Teardown, Remove the battery: 5 단계, 이미지 3개 중 2개 Pocket C.H.I.P. Teardown, Remove the battery: 5 단계, 이미지 3개 중 3개
    • Next, we need to remove the LiPo battery.
    • First, we need to unplug it from the CHIP. Simply pull it from the connector.
    • There is some adhesive holding the battery to the main board. I found twisting it while pulling worked wonders.
    • Be careful not to puncture the battery and follow proper battery-handling precautions.
  6. Pocket C.H.I.P. Teardown, Unplug the screen: 6 단계, 이미지 2개 중 1개 Pocket C.H.I.P. Teardown, Unplug the screen: 6 단계, 이미지 2개 중 2개
    • The screen connector was hidden by the battery. Now that it's revealed, we can do our thing.
    • Pull the black bar up on both sides. It should come out completely.
    • You can now pull the ribbon cable up.
  7. Pocket C.H.I.P. Teardown, Removing the screen: 7 단계, 이미지 3개 중 1개 Pocket C.H.I.P. Teardown, Removing the screen: 7 단계, 이미지 3개 중 2개 Pocket C.H.I.P. Teardown, Removing the screen: 7 단계, 이미지 3개 중 3개
    • There is some adhesive behind the screen. I put a card behind it and kind of sawed it off to remove it.
  8. Pocket C.H.I.P. Teardown, The finale: 8 단계, 이미지 1개 중 1개
    • That's it, we've taken apart the Pocket chip! The only pieces are
    • The main board with the keyboard
    • The main CHIP computer
    • The LiPo battery
    • The screen
    • And the back case.
작성자
1다른 기여자 명과 함께
askaye
회원 가입일: 09/23/23
182 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 60
전체 시간: 581
