주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Table Lamp 수리는 자사의 서비스 설명서를 사용하세요.
  1. Portable Luminaries Lamp Teardown, Portable Luminaries Lamp Teardown: 1 단계, 이미지 1개 중 1개
    • The attached picture displays the lamp before the teardown.
  2. Portable Luminaries Lamp Teardown: 2 단계, 이미지 1개 중 1개
    • Remove the power cord from the wall socket outlet
    • Make sure to follow this step. There may be a danger of severe electric shock if you proceed to tear down the device without removing the plug
  3. Portable Luminaries Lamp Teardown: 3 단계, 이미지 2개 중 1개 Portable Luminaries Lamp Teardown: 3 단계, 이미지 2개 중 2개
    • Place the lamp gently on its side on a flat surface
    • Twist the lightbulb counter-clockwise to remove it from the lamp's head.
    • After lightbulb removal, the component attaching the lightbulb and lamp's head is exposed.
  4. Portable Luminaries Lamp Teardown: 4 단계, 이미지 2개 중 1개 Portable Luminaries Lamp Teardown: 4 단계, 이미지 2개 중 2개
    • Next, the light bulb housing can be detached from the lamp head
    • Using the Philips screw driver, unscrew the two 5mm diameter screws within the light bulb housing
  5. Portable Luminaries Lamp Teardown: 5 단계, 이미지 2개 중 1개 Portable Luminaries Lamp Teardown: 5 단계, 이미지 2개 중 2개
    • Keep the lamp on its side
    • The bottom is now exposed and two screws are visible
    • Using the Philips Screwdriver, unscrew the two 7mm gold screws from the bottom of the base
  6. Portable Luminaries Lamp Teardown: 6 단계, 이미지 2개 중 1개 Portable Luminaries Lamp Teardown: 6 단계, 이미지 2개 중 2개
    • Once the screws attached to the base are removed, the base's bottom lid detaches from the lamp.
    • Within the base resides two components: the lamp's weight and the switch.
    • The weight sits on the bottom base lid, so it separates without the use of additional tools.
  7. Portable Luminaries Lamp Teardown: 7 단계, 이미지 1개 중 1개
    • The white container holding the switch does not need tools for opening.
    • The switch container is clipped shut and opens by unlatching the tab
작성자
3다른 기여자 명과 함께
Brenden
회원 가입일: 11/17/14
56 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 31
전체 시간: 1,873
