주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Power Mac G4 M5183 수리는 저희 서비스 설명서를 사용하십시오.
  1. Power Mac G4 M5183 Teardown STEM Project, Case: 1 단계, 이미지 1/2 Power Mac G4 M5183 Teardown STEM Project, Case: 1 단계, 이미지 2/2
    • Pull the tab to open the case.
  2. Power Mac G4 M5183 Teardown STEM Project, RAM: 2 단계, 이미지 1/2 Power Mac G4 M5183 Teardown STEM Project, RAM: 2 단계, 이미지 2/2
    • Pull the white tabs down
    • Lift up the RAM
    • Repeat x4
  3. Power Mac G4 M5183 Teardown STEM Project, Heat-sink: 3 단계, 이미지 1/2 Power Mac G4 M5183 Teardown STEM Project, Heat-sink: 3 단계, 이미지 2/2
    • Use a flat head screwdriver or spudger to lift up the tabs that hold down the heat-sink.
    • Repeat x2
    • The heat-sink should just lift right off.
  4. Power Mac G4 M5183 Teardown STEM Project, GPU: 4 단계, 이미지 1/2 Power Mac G4 M5183 Teardown STEM Project, GPU: 4 단계, 이미지 2/2
    • Remove highlighted screw.
    • The GPU should lift right out.
  5. Power Mac G4 M5183 Teardown STEM Project, Mother Board: 5 단계, 이미지 1/3 Power Mac G4 M5183 Teardown STEM Project, Mother Board: 5 단계, 이미지 2/3 Power Mac G4 M5183 Teardown STEM Project, Mother Board: 5 단계, 이미지 3/3
    • Remove highlighted cables.
    • Remove highlighted screws.
    • Lift out the motherboard. (Note: pull to the left to clear the ports from the case)
  6. Power Mac G4 M5183 Teardown STEM Project, CPU: 6 단계, 이미지 1/2 Power Mac G4 M5183 Teardown STEM Project, CPU: 6 단계, 이미지 2/2
    • After removing the screws, simply lift off the CPU from the connector. Use only a minimal amount of pressure when pulling the CPU from the connector.
    • This is the connector after removal of the CPU.
  7. Power Mac G4 M5183 Teardown STEM Project, DVD/ROM drive: 7 단계, 이미지 1/3 Power Mac G4 M5183 Teardown STEM Project, DVD/ROM drive: 7 단계, 이미지 2/3 Power Mac G4 M5183 Teardown STEM Project, DVD/ROM drive: 7 단계, 이미지 3/3
    • Remove the face plate. You are supposed to press down the highlighted tabs from the inside.
    • Slide out the drive. (MAKE SURE TO UNHOOK THE CABLES)
  8. Power Mac G4 M5183 Teardown STEM Project, Hard drive: 8 단계, 이미지 1/3 Power Mac G4 M5183 Teardown STEM Project, Hard drive: 8 단계, 이미지 2/3 Power Mac G4 M5183 Teardown STEM Project, Hard drive: 8 단계, 이미지 3/3
    • Remove the highlighted cables.
    • Lift out the hard drive.
  9. Power Mac G4 M5183 Teardown STEM Project, Main Fan: 9 단계, 이미지 1/2 Power Mac G4 M5183 Teardown STEM Project, Main Fan: 9 단계, 이미지 2/2
    • Remove highlighted screw. ( SAME SCREW ON OPPOSITE SIDE, REMOVE THAT AS WELL.)
    • Disconnect the connector.
    • After that, just pull it out.
  10. Power Mac G4 M5183 Teardown STEM Project, Power Supply: 10 단계, 이미지 1/3 Power Mac G4 M5183 Teardown STEM Project, Power Supply: 10 단계, 이미지 2/3 Power Mac G4 M5183 Teardown STEM Project, Power Supply: 10 단계, 이미지 3/3
    • Use a 2.5 mm hex key to remove these screws.
    • Feed the wires through the highlighted hole, then pull out the power supply.
  11. Power Mac G4 M5183 Teardown STEM Project, Finished!: 11 단계, 이미지 1/1
    • You will be left with an empty case.
Harrison Case
회원 가입일: 11/06/16
128 평판
안내서 1개 작성함
댓글 4개
Just a little tip.
APPLE tend to use screw connections as a means of ground continuity.
That is - if the CPU card is not screwed down - it might not power on.
Mal - 답글
The is a kit from thelaserhive.com to allow an mATX board to be used inside the G4 cases.
Pete Karnowski - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 45
전체 시간: 3,369
