주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Power Macintosh 8600(250) 수리는 저희 서비스 설명서를 사용하십시오.
  1. Power Macintosh 8600(250) Teardown, Power Macintosh 8600(250) Teardown: 1 단계, 이미지 1/1
    • There she is! i'm missing the bezel around the floppy drive :(
  2. Power Macintosh 8600(250) Teardown: 2 단계, 이미지 1/3 Power Macintosh 8600(250) Teardown: 2 단계, 이미지 2/3 Power Macintosh 8600(250) Teardown: 2 단계, 이미지 3/3
    • Start by pressing the big green button. And pulling the door away and up from the computer.
    • And on the Back of the door is the fan.
  3. Power Macintosh 8600(250) Teardown: 3 단계, 이미지 1/3 Power Macintosh 8600(250) Teardown: 3 단계, 이미지 2/3 Power Macintosh 8600(250) Teardown: 3 단계, 이미지 3/3
    • Now it's best to lay the computer flat.
    • And to flip up the tabs, grab the handle and open.
  4. Power Macintosh 8600(250) Teardown: 4 단계, 이미지 1/1
    • The innards, motherboard, daughter board, RAM and so fourth.
  5. Power Macintosh 8600(250) Teardown: 5 단계, 이미지 1/3 Power Macintosh 8600(250) Teardown: 5 단계, 이미지 2/3 Power Macintosh 8600(250) Teardown: 5 단계, 이미지 3/3
    • Now the speaker
    • Remove the speaker wires
    • And the fan wires from the motherboard
    • Push in the two plastic tabs on either side and lift the speaker up and out.
  6. Power Macintosh 8600(250) Teardown: 6 단계, 이미지 1/2 Power Macintosh 8600(250) Teardown: 6 단계, 이미지 2/2
    • The PRAM battery!
    • Remove the housing by pulling it out and then take the battery out.
  7. Power Macintosh 8600(250) Teardown: 7 단계, 이미지 1/3 Power Macintosh 8600(250) Teardown: 7 단계, 이미지 2/3 Power Macintosh 8600(250) Teardown: 7 단계, 이미지 3/3
    • The processor, firmly grasp and pull out.
    • Remove the 4 #1 Phillips screws
    • And push the 4 tabs off of the board
    High failure rate - these bassas’
    Mal - 답글
  8. Power Macintosh 8600(250) Teardown: 8 단계, 이미지 1/1
    • Any video card or usb card, mine happens to be an ethernet 10/100 card.
    • Unfortunately there are 6 spaces but only 3 slots on the motherboard :(
    • Remove the #1 Phillips screw and pull the card out.
  9. Power Macintosh 8600(250) Teardown: 9 단계, 이미지 1/1
    • RAM and VRAM slots!
  10. Power Macintosh 8600(250) Teardown: 10 단계, 이미지 1/3 Power Macintosh 8600(250) Teardown: 10 단계, 이미지 2/3 Power Macintosh 8600(250) Teardown: 10 단계, 이미지 3/3
    • Moving on to the CD, ZIP, and Floppy drives (best to close computer now)
    • Remove the bezels and if I had the top one remove that too.
    • Remove the 6 phillips screws and pull the metal frames out.
  11. Power Macintosh 8600(250) Teardown: 11 단계, 이미지 1/3 Power Macintosh 8600(250) Teardown: 11 단계, 이미지 2/3 Power Macintosh 8600(250) Teardown: 11 단계, 이미지 3/3
    • Remove the data and power cables
    • Pay special attention to this one, it has a clip on it, it helps to use a flathead or a spudger.
    • Pull the drives out of the bay.
  12. Power Macintosh 8600(250) Teardown: 12 단계, 이미지 1/2 Power Macintosh 8600(250) Teardown: 12 단계, 이미지 2/2
    • Now the hard drive.
    • Remove the two phillips screws
    • And the data and power cables (might help to remove them as you pull the drive out)
  13. Power Macintosh 8600(250) Teardown: 13 단계, 이미지 1/3 Power Macintosh 8600(250) Teardown: 13 단계, 이미지 2/3 Power Macintosh 8600(250) Teardown: 13 단계, 이미지 3/3
    • The power source
    • Remove the two connectors
    • There is a clip holding the wires in place. Separate and remove the wires. (both sets)
  14. Power Macintosh 8600(250) Teardown: 14 단계, 이미지 1/3 Power Macintosh 8600(250) Teardown: 14 단계, 이미지 2/3 Power Macintosh 8600(250) Teardown: 14 단계, 이미지 3/3
    • Now remove the 4 phillips screws (it's best to start with the bottom two)
    • And pull it out while de-threading the wires.
Plague
회원 가입일: 06/14/10
181 평판
안내서 1개 작성함
댓글 한 개
Nice. I got a beige G3 300 Mhz, the case is similar. Maybe I could also make a teardown.
Nicolas Zbinden - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 29
전체 시간: 15,278
