주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. PowerA Moga Rebel MFI iPhone controller 수리는 자사의 서비스 설명서를 사용하세요.
  1. PowerA Moga Rebel MFI iPhone controller Teardown, Turn Off Controller: 1 단계, 이미지 2개 중 1개 PowerA Moga Rebel MFI iPhone controller Teardown, Turn Off Controller: 1 단계, 이미지 2개 중 2개
    • Lift the phone mount from the bottom. It swivels on a hinge at the top of the controller.
    • Turn the switch to the left "OFF" position, so that red is showing.
  2. PowerA Moga Rebel MFI iPhone controller Teardown, Remove Case Screws: 2 단계, 이미지 1개 중 1개
    • Unscrew the 8 identical case screws with a PH1 Philips bit.
  3. PowerA Moga Rebel MFI iPhone controller Teardown, Lift Back Case: 3 단계, 이미지 3개 중 1개 PowerA Moga Rebel MFI iPhone controller Teardown, Lift Back Case: 3 단계, 이미지 3개 중 2개 PowerA Moga Rebel MFI iPhone controller Teardown, Lift Back Case: 3 단계, 이미지 3개 중 3개
    • Make sure the phone mounting arm is up, and then separate the back cover along the visible seem.
    • The triggers (L2 and R2) can be pushed in to help lift the back case.
    • No cables or other internal parts are attached to the back, but the reset button may fall out when lifting it.
    • The third image and red circle show where the reset button goes from the inside of the controller.
  4. PowerA Moga Rebel MFI iPhone controller Teardown, Take A Look Around!: 4 단계, 이미지 3개 중 1개 PowerA Moga Rebel MFI iPhone controller Teardown, Take A Look Around!: 4 단계, 이미지 3개 중 2개 PowerA Moga Rebel MFI iPhone controller Teardown, Take A Look Around!: 4 단계, 이미지 3개 중 3개
    • Reparability flaws are now visible:
    • The micro USB daughter board is separate from the main board, which would be otherwise good, except that it is melted in with plastic, and the wires are soldered on.
    • Like the micro USB port, the small (3.7V, 680mAh, 2.52 Wh) battery is soldered on to the main board. By design, replacing the battery needs a soldering iron.
    • Setting flaws aside, a weight can be seen in the controller. It is on the right side of the controller pictured, and the left side when held. It can be lifted out without tools. The added weight is 25 grams, contributing 12.8% of the controllers weight (195g).
  5. PowerA Moga Rebel MFI iPhone controller Teardown, Unscrew The Main Board: 5 단계, 이미지 3개 중 1개 PowerA Moga Rebel MFI iPhone controller Teardown, Unscrew The Main Board: 5 단계, 이미지 3개 중 2개 PowerA Moga Rebel MFI iPhone controller Teardown, Unscrew The Main Board: 5 단계, 이미지 3개 중 3개
    • Lift the battery, which covers the left screw.
    • Use the JIS0 (Philips) bit. Unscrew the black screw, which is circled in pink. Next, unscrew the two identical silver screws, circled in blue. Unscrew the black screw, which is circled in pink.
    • The silver screws secures the trigger components and main board to the top case. The black screw secures the main board to the D-pad board.
    • There is a small black wire antenna for bluetooth. It is taped on to the plastic case to the left of the micro USB port. use a spudger to lift the tape.
  6. PowerA Moga Rebel MFI iPhone controller Teardown, Lift The Main Board: 6 단계, 이미지 3개 중 1개 PowerA Moga Rebel MFI iPhone controller Teardown, Lift The Main Board: 6 단계, 이미지 3개 중 2개 PowerA Moga Rebel MFI iPhone controller Teardown, Lift The Main Board: 6 단계, 이미지 3개 중 3개
    • Take the board out of the case by lifting it up (keeping it as level as possible), and then down.
    • Fold the main board over above the case.
    • the A B X Y and D-pad buttons are connected without being soldered. repairs are still complicated by the adhesive used to keep them in place. Additionally, the D-pad shares the cable with the L1 shoulder button, and the A B X Y shares with the R1 shoulder button.
  7. PowerA Moga Rebel MFI iPhone controller Teardown, Buttons, Buttons, Buttons!: 7 단계, 이미지 3개 중 1개 PowerA Moga Rebel MFI iPhone controller Teardown, Buttons, Buttons, Buttons!: 7 단계, 이미지 3개 중 2개 PowerA Moga Rebel MFI iPhone controller Teardown, Buttons, Buttons, Buttons!: 7 단계, 이미지 3개 중 3개
    • The L1 and R1 buttons can be removed. They can be removed without lifting the main board.
    • The A B X Y buttons can be removed, along with the pause, bluetooth pairing mode, and battery button. The battery button is not pictured. The pause button is in the bottom left of the first photo, and uses a rubber pad.
    • The D-pad can be lifted out, and the power switch can be too.
  8. PowerA Moga Rebel MFI iPhone controller Teardown, Problematic Joysticks: 8 단계, 이미지 1개 중 1개
    • The joystick cover is glued to the joystick switch, making cosmetic replacements virtually impossible .
    • The joystick switch is soldered onto the main board, making replacing them for drift very difficult, or impossible.
작성자
1다른 기여자 명과 함께
Philip Sophocleous
회원 가입일: 02/18/18
308 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 50
전체 시간: 1,224
