주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Powerbeats Pro 수리는 자사의 서비스 설명서를 사용하세요.
    최종 의견
    • The battery is a fairly common button-cell, and is only lightly soldered in place, meaning battery swaps are technically possible with the right tools.
    • The earbuds’ opening procedure is not totally destructive per se, but it will likely lead to at least some cosmetic damage.
    • The earbuds’ internal circuitry is all connected with fragile ribbon cables that do not detach, so a full disassembly can only be accomplished destructively.
    • The charging case is a nightmarish bucket of glue, making potential battery replacements unnecessarily difficult and destructive.
    수리 용이성 점수
    수리 용이성 10점 중 1점
    (10은 가장 쉬운 수리를 뚯함)
Taylor Dixon
회원 가입일: 06/26/18
70,371 평판
안내서 94개를 작성함
8가이드 댓글
Review missed the debris screens in the ear tubes which often get damaged. How to replace possibly.
chronus - 답글
I can’t connect them when they are in the case are connect if I take them out of the case they disconnected. and it says they need to be on and on range help please
Eduardo Gaspar - 답글
So far it is just the case for mine that seems broken - It won’t charge the buds properly. I really don’t mind cosmetic damage if I can replace the case’s battery (assuming that is the culprit). Where might I get a replacement battery? Also, if I used enough care, could I not just cut into the case closer to the battery to get at it from underneath?
Tom Hernandez - 답글
I pushed my mesh in on one of my pods. Is there any fix to just bring it back?
AuxCord Broke - 답글
My volume button is stuck. It will turn up and change songs. However I can not turn down the volume at all. Can I fix it somehow?
Lisa Nikodym - 답글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 81
지난 30일: 336
전체 시간: 46,835
