해당 분해도에 사용된 도구
소개
They say it takes four to Tango, or something like that. In Google's case, it takes two. Google's Project Tango is in its second iteration, this time taking the form of a tablet. Join us as we unravel the new goodies that Google has packed into the Project Tango Tablet.
We did our fact checking with Google-the-man himself, so keep an eye out for some primary source, horse's mouth reveals.
Welcome back, Project Tango. It's been a while since you've graced us with your presence. Of course, take a seat. Would you like a glass of water? No? Oh you're here for a teardown? Gladly.
Project Tango is growing up fast; let's check its specs on the home height chart:
7" HD 1920 x 1200 (323 ppi) touchscreen display
120˚ front-facing camera + 4 MP RGB-IR rear-facing camera along with a 170˚ motion tracking camera
2.3 GHz quad-core NVIDIA Tegra K1 CPU
4 GB RAM
128 GB flash memory, expandable via microSD
Google's ATAP (Advanced Technology and Projects) team, not to be confused with the Arkansas Taxpayer Access Point (ATAP) group, have stepped up their design game.
The Project Tango tablet is far more polished than the Project Tango phone. The thicker portion of the tablet allows room for the additional cameras, but slims down to a more typical tablet thickness.
The new design also includes a non-standard dock connector that allows for 12 V high-speed charging and USB 3.0.
Moving right along, it's time to separate the camera board. Except it's not, because it's connected to the motherboard by several cables, trapped under a metal bracket.
Getting closer...
While we've got these connectors exposed, let's go ahead and
defusedisconnect the battery.
For mine, the metal cover over connections to the main-board (from step 14) was hooked on the left side to the main-board and had to slide it to left to remove it. For which I had to first remove the "Nvidia NB106-N baseband module" from step 11 before I could remove the metal cover. Also, all the connections were covered with sticky tape and required extra caution not to damage the connections.
We can't help but notice the resemblance to the Kinect.
There are several ICs on the camera control board:
STMicroelectronics STM32L151QD Ultra-low-power ARM Cortex-M3 MCU
NXP Semiconductors PCA9546A in HVQFN16 package (546A 0108 TXD403)
Linear Tech LT3743 in QFN package (4C 3743 N3580)
ON Semiconductor NCP45560 Controlled Load Switch
Let's remove the camera module assembly to get a closer look at the cameras themselves.
The IR projector is tucked within the camera assembly, but our trusty tweezers make removing it a breeze.
Curious how this works? We've got you covered. Science with iFixit is ready to satisfy all of your IR curiosities.
Looks like we found out what the "cam glue" marking meant! The two rear-facing cameras are hot-glued to the camera assembly, making replacement difficult.
Mapping an entire space in 3D requires a hefty source of power. Luckily the Project Tango tablet has just that.
A bit of light adhesive is all that anchors the battery to the front panel assembly.
The dual-cell 7.6 V Li-ion polymer battery is rated at around 18 Wh of energy, well over the Tango Phone's already-hefty 11.1 Wh.
While scouring inside the Project Tango tablet we came across this Nvidia NB106-N baseband module.
Notable ICs on the baseband module:
Nvidia ICE9245B-C2 low-power, multi-mode RF transceiver
Micron 3PA98 JW806 NAND-based MCP
Nvidia Icera ICE9045T-A2 LTE Modem
Texas Instruments TPS659121A PMU for Processor Power
Skyworks 77621-11 Multimode Multiband Power Amplifier Module
Prominent ICs driving the Project Tango tablet:
Nvidia TD580D-A1 2.3 GHz quad-core Tegra K1 processor
SanDisk 4133DF4PG02X 128 GB flash memory
Elpida FA232A2MA 2 GB LPDDR3 RAM (two ICs for 4 GB total)
Broadcom BCM4752IUB2G integrated multi-constellation GNSS receiver
Broadcom BCM43341XKUBG single-chip dual-band combo device supporting 802.11n, Bluetooth 4.0+HS & FM receiver
Realtek ACL5642 Hi-Fi audio single chip with voice/sound DSP and CODEC
Texas Instruments 45A2RFI
More antennas! The rear case obviously wasn't enough to keep this device 100% connected. This bar holds a couple extra stuck-on antennas.
In what has become a staple of life as we know it, the Project Tango tablet has a front-facing camera with a 120˚ field of view, perfect for all your selfie needs.
The front-facing camera is labeled as P1V09A-1.
This is starting to get ridiculous. We're drowning in a sea of antennas. These little guys live on the top and bottom right corners of the device, and are probably really important.
Teardown Update: We have it on good word that the left green doohickey is the GPS antenna, while the right green doohickey is the Wi-Fi antenna.
With a few turns of our trusty Phillips #00 screwdriver, we free two antenna boards from the Tango.
Green ceramic chip antenna - Unictron GPS/Glonass (AA088)
Blue ceramic chip antenna - Unictron WiFi dual band 2.4GHz and 5GHz (AA077)
A hefty amount of adhesive holds the headphone jack, microSD, and SIM card assembly down, but it comes out easily with a little work.
This is also the first time we've seen a microSD card slot with a paperclip-actuated tray, commonly seen in SIM slots.
it is no where as difficult to remove the SD card Tray as it was on my tango. I destroyed the tango SD Remover key in the process
crazzyjohn - 답글
This looks familiar. It's a component that protrudes through the edge of the case, is adhered to the back of the display assembly, and has a fairly long ribbon cable to connect it to the motherboard, probably by reaching over the battery.
So what we're saying is that we've gone back in time. Welcome back to the step immediately preceding this one. Now with USB and HDMI instead of card slots and headphone jack.
With that, we're about tapped out for pulling gently-glued-in bits out of the back of this display assembly. Time to disassemble the assembly and pull out the un-gently-glued-in glass and LCD.
But before we go, we spy a touchscreen controller! RM31280 50051 1418A1U0
Also of note is the sweet grab-bag cable we're leaving behind: power/volume buttons, camera connectors, and front-facing microphone.
Before we bring out the heat, a little probing reveals easily-removed speaker grilles. This will make prying the display out considerably easier. Great!
Grilles out, let's throw this puppy on the grill. Or maybe under the broiler. The iOpener broiler.
After plenty of prying around the edge of the display panel, we get the screen up and out from the frame.
Our hard works pays off! We get a first look at the hidden Sharpie hieroglyphics of the production and QA notes.
This 7" HD 1920 x 1200 (323 ppi) touchscreen display is based off a tested standard—the Nexus 7 2nd Generation.
Where can i get a lcd screen + digitizer assembly for this tab?
I am looking for one too if you figure it out please let me know too.
Project Tango Tablet Repairability Score: 4 out of 10 (10 is easiest to repair).
The rear case is super easy to open with no screws or adhesives—only plastic clips.
Several cables cover the battery and make it a pain to remove—but at least you don't need to melt adhesive.
Low modularity—several components soldered to the same components makes replacement parts more expensive.
Complex internal construction—this thing is full of cables and not at all fun to disassemble or reassemble.
댓글 5개
I would love to know that detail as well.
My tango dev-kit tablet fell from a height of about one meter. The screen failed and did not display anything. It did power the screen (backlight) and the touch worked. But the screen was black and did not display anything.
I was hoping that the damage was not substantial, something like a connection problem. I opened the tablet following the revertible steps in this instruction. Assembled again and now it's working! This was really exciting , thank you so much :)
