주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. BlackBerry Pearl 8130 수리는 저희 서비스 설명서를 사용하십시오.
  1. RIM Blackberry Pearl 8130 Teardown, RIM Blackberry Pearl 8130 Teardown: 1 단계, 이미지 1/2 RIM Blackberry Pearl 8130 Teardown, RIM Blackberry Pearl 8130 Teardown: 1 단계, 이미지 2/2
    • Frontal/Back View- Dimensions: (LxWxD) 107mm x 50mm x 14mm (4.02" x 1.97" x .55") <- For those in America :) Weight: 96g or 3.10oz
    • Speaker
    • Status LED
    • High-res 240x260 Color LCD display
    • Red Trackball
    • 1.3MP Camera
    • Flash
    • Back Cover Latch
  2. RIM Blackberry Pearl 8130 Teardown: 2 단계, 이미지 1/2 RIM Blackberry Pearl 8130 Teardown: 2 단계, 이미지 2/2
    • Side View!
    • 3.5mm Stereo Headset Jack
    • USB 2.0 Data/Charging Port
    • Micro SD Card Slot
    • Camera/Quick Access Button
    • Volume Up/Down Button
    • Quick Access Button
    • Lanyard/Accessory Attachment
  3. RIM Blackberry Pearl 8130 Teardown: 3 단계, 이미지 1/2 RIM Blackberry Pearl 8130 Teardown: 3 단계, 이미지 2/2
    • Top/Bottom!
    • This phone his seen it's share of scratches!
    • Mute/Ringer Off Button
    • Microphone
  4. RIM Blackberry Pearl 8130 Teardown: 4 단계, 이미지 1/3 RIM Blackberry Pearl 8130 Teardown: 4 단계, 이미지 2/3 RIM Blackberry Pearl 8130 Teardown: 4 단계, 이미지 3/3
    • Press down on clip and remove back cover.
    • Push Battery from top to bottom and pull up to remove.
    • Battery: Standby time- 216 hours/Call time- 4 hours
    • Clip
    • Back cover
  5. RIM Blackberry Pearl 8130 Teardown: 5 단계, 이미지 1/2 RIM Blackberry Pearl 8130 Teardown: 5 단계, 이미지 2/2
    • 1.3MP Camera
    • Flash
    • QuALCOMM 3G CDMA
    • Phone information sticker
    • Torx T5 screws
  6. RIM Blackberry Pearl 8130 Teardown: 6 단계, 이미지 1/3 RIM Blackberry Pearl 8130 Teardown: 6 단계, 이미지 2/3 RIM Blackberry Pearl 8130 Teardown: 6 단계, 이미지 3/3
    • Insert curved point metal spudger into gap between keyboard and bottom bezel cap.
    • Bottom Bezel Cap
    • Pull up and push away to lift bezel.
    • Hold this cap with your thumb and flip the phone around.
    • Insert spudger under bezel and lift on both sides.
    • Pry Here
    • The Bezel Cap should pop off at this point revealing two more T5 screws!
    • Two T5 Screws
  7. RIM Blackberry Pearl 8130 Teardown: 7 단계, 이미지 1/3 RIM Blackberry Pearl 8130 Teardown: 7 단계, 이미지 2/3 RIM Blackberry Pearl 8130 Teardown: 7 단계, 이미지 3/3
    • Remove the two T5 Screws and set them aside.
    • The two T5 screws and their respective holes
    • Start at the top of one of the sides of the phone and pry off the silver sides with a spudger or your fingers.
    • Once you have removed both sides set them aside
    • The silver sides
    • Various holes, buttons and slots
  8. RIM Blackberry Pearl 8130 Teardown: 8 단계, 이미지 1/3 RIM Blackberry Pearl 8130 Teardown: 8 단계, 이미지 2/3 RIM Blackberry Pearl 8130 Teardown: 8 단계, 이미지 3/3
    • Headphone Jack
    • USB 2.0 Port
    • Camera Button
    • Up and Down Buttons
  9. RIM Blackberry Pearl 8130 Teardown: 9 단계, 이미지 1/1
    • Pry front cover and back cover off of LCD and circuit board.
    • Separate the three parts and set them down.
    • Back plastic assembly
    • LCD and Logic Board
    • Front plastic assembly and keypad+trackball
  10. RIM Blackberry Pearl 8130 Teardown: 10 단계, 이미지 1/3 RIM Blackberry Pearl 8130 Teardown: 10 단계, 이미지 2/3 RIM Blackberry Pearl 8130 Teardown: 10 단계, 이미지 3/3
    • Trackball (Removable). Pop it out from the back.
    • Display Glass (Removable). Pry from the top to break glue seal, pry the rest of with your fingers.
    • Keypad
    • LCD and connector above it to the left (Removable). Remove connector with spudger and free LCD from clips.
    • Keypad connector (Keypad was removed). To remove pry connector up off of logic board.
    • Battery Connector
    • Various chips under metal heat sinks. Sorry I won't remove them the phone is still good and I don't want to risk damaging it :(
  11. RIM Blackberry Pearl 8130 Teardown: 11 단계, 이미지 1/3 RIM Blackberry Pearl 8130 Teardown: 11 단계, 이미지 2/3 RIM Blackberry Pearl 8130 Teardown: 11 단계, 이미지 3/3
    • Speaker (Removable by Soldering)
    • Keyboard Connector
    • Trackball (Remove by poking out)
    • 1.3MP Camera (Removable by Soldering)
    • From left to right: Headphone jack, Antenna?, USB Port, Micro SD Card Slot. All of the above are removable by soldering.
    • Battery Connector (Removable by pulling it straight out of it's slot)
    • Various chips covered by heatsinks
  12. RIM Blackberry Pearl 8130 Teardown: 12 단계, 이미지 1/1
    • Here it is, everything all laid out.
    • Back Cover and Battery
    • T5 Screws
    • Bezel cap
    • Shiny Side pieces
    • Front Plastic Assembly
    • Back Plastic Assembly
Liam Speirs
회원 가입일: 11/08/09
363 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 14,098
