주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Razer Huntsman Elite Gaming Keyboard 수리는 자사의 서비스 설명서를 사용하세요.
  1. Razer Huntsman Elite Gaming Keyboard Teardown, Overhead View: 1 단계, 이미지 1개 중 1개
    • Top view of the keyboard.
  2. Razer Huntsman Elite Gaming Keyboard Teardown, Remove Key Caps: 2 단계, 이미지 1개 중 1개
    • Remove all key caps by pulling them directly upwards.
  3. Razer Huntsman Elite Gaming Keyboard Teardown, Remove All Front Screws: 3 단계, 이미지 2개 중 1개 Razer Huntsman Elite Gaming Keyboard Teardown, Remove All Front Screws: 3 단계, 이미지 2개 중 2개
    • There are 18 JIS-1 screws in-between key switches. Remove all screws (see red circles). Be extremely careful if using a Phillips-1 instead of a JIS-1 as Phillips screwdrivers can destroy JIS screws.
  4. Razer Huntsman Elite Gaming Keyboard Teardown, Remove All Back Screws: 4 단계, 이미지 2개 중 1개 Razer Huntsman Elite Gaming Keyboard Teardown, Remove All Back Screws: 4 단계, 이미지 2개 중 2개
    • Under the six rubber pads are eight JIS-1 screws that need to be removed. The edges of the pads can be lifted to access the screws without having to remove the entire pad. Using a small flat-blade screw driver can help with lifting the corner(s).
    • Gently pry the black cover up away from the main body. Be careful not to damage the wires.
    • I apparently forgot to take pictures of this step.
  5. Razer Huntsman Elite Gaming Keyboard Teardown, Remove LED Light Logic Board Screws: 6 단계, 이미지 3개 중 1개 Razer Huntsman Elite Gaming Keyboard Teardown, Remove LED Light Logic Board Screws: 6 단계, 이미지 3개 중 2개 Razer Huntsman Elite Gaming Keyboard Teardown, Remove LED Light Logic Board Screws: 6 단계, 이미지 3개 중 3개
    • Nine JIS-1 screws secure the back LED logic board. Remove all of them.
    • The back LED logic board is connected to the main PCB by a cable. Carefully disconnect the cable.
  6. Razer Huntsman Elite Gaming Keyboard Teardown, Pry Open the Plastic Panel: 7 단계, 이미지 1개 중 1개
    • The transparent plastic gasket is tightly locked to the main frame via small plastic tabs all around the outside edge. Use the jimmy tool to carefully remove the panel.
  7. Razer Huntsman Elite Gaming Keyboard Teardown, Remove Main Frame Screws: 8 단계, 이미지 2개 중 1개 Razer Huntsman Elite Gaming Keyboard Teardown, Remove Main Frame Screws: 8 단계, 이미지 2개 중 2개
    • There are three tiny JIS-000 screws that keep the main frame and the printed circuit board together. Remove the red circled screws before you separate them.
  8. Razer Huntsman Elite Gaming Keyboard Teardown, Disconnect Printed Circuit Board (PCB) Board Cables: 9 단계, 이미지 2개 중 1개 Razer Huntsman Elite Gaming Keyboard Teardown, Disconnect Printed Circuit Board (PCB) Board Cables: 9 단계, 이미지 2개 중 2개
    • There are two cables connected to the PCB. Carefully separate the main frame and the PCB, then disconnect the lower cable first.
    • With the lower cable disconnected, the PCB can be flipped upright so as to easily remove the upper cable.
  9. Razer Huntsman Elite Gaming Keyboard Teardown, Logical Board: 10 단계, 이미지 1개 중 1개
    • Now the logic board is revealed and can be cleaned up.
작성자
6다른 기여자 명과 함께
Will Huang
회원 가입일: 07/22/19
169 평판
안내서 1개를 작성함
댓글 13개
are the actual keys soldiered to the board or they are hot replaceable?
Tawshif Ahsan khan - 답글
The switches have no electrical contacts, they are only mechanical components. The LED and photodiode that read each switch are soldered to the main PC board. So to answer your question: no, the switches are not soldered to the PCB.
Enrico Savazzi -
Does anyone know what kind of LED's are being used on this keyboard? The green on one of the LED's has burned out and I would like to replace it.
Valentino Damianou - 답글
Anyone know if the rotary dial can be replaced? Mine does not act properly and turning it in one direction causes changes in value that are both inconsistent in value and direction. Very weird.
Armando Wirshing - 답글
Just use some WD40 on it, I did it, had the same problem and it fixed it.
Jonathan José Ramírez Zaragoza -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 40
지난 30일: 244
전체 시간: 20,188
