주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Tweezers 수리는 저희 서비스 설명서를 사용하십시오.
  1. Reversed tweezers Teardown, Reversed tweezers Teardown: 1 단계, 이미지 1/3 Reversed tweezers Teardown, Reversed tweezers Teardown: 1 단계, 이미지 2/3 Reversed tweezers Teardown, Reversed tweezers Teardown: 1 단계, 이미지 3/3
    • This my friends, is the first ever iFixit-made-tool teardown on iFixit
    • Stainless steel body and nylon tips, with the iFixit logo printed on it...
    • Reversed so you can hold tiny Lego hats even when your hands are busy...
  2. Reversed tweezers Teardown: 2 단계, 이미지 1/3 Reversed tweezers Teardown: 2 단계, 이미지 2/3 Reversed tweezers Teardown: 2 단계, 이미지 3/3
    • Time to tear it down!
    • Its not often that regular Philips screws are used on modern devices!
    • So far we've been able to take off a lot of the tool's construction using Only a PH0 screwdriver!
    • Have dreams come true?
    • We Remove the Last parts anddddd...
  3. Reversed tweezers Teardown, Final Thoughts: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Nylon Tipped Tweezers
    $2.99
    구매
    What is the pitch between the screw holes?
    Colton - 답글
    Also, do you know what the thickness of the tips are and the length of the screws?
    Colton - 답글
Aiden
회원 가입일: 09/19/15
17,429 평판
안내서 21개 작성하였습니다
댓글 8개
Where can you find the replacement parts?
echow2001 - 답글
Repairability: 11 out of 10.
Jake Rose - 답글
lol i actually needed this to fix mine
Luke - 답글
Very glad to know replacement tips are sold! I had no idea these were nylon until I melted the ends. Whoops!
The Purple Ender Eye - 답글
If you have the order number of the original or a photo of the kit it came with, theyll replace it for free if you use their email support.
Tito_deTrapio94 -
So I have to purchase the Nylon Tipped Tweezers to get a set of Nylon Tips to replace my Reverse Tweezers Nylon Tips? Can't jus buy the tips?
Randy
Clarence Hayes - 답글
You can definitely get the tips only. And they are covered by the lifetime warranty. Just contact their email support. they sent me 2 replacement packs for free.
Tito_deTrapio94 -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 41
전체 시간: 3,502
