주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Revlon Perfect Heat Jumbo 3 Barrel Waver 수리는 저희 서비스 설명서를 사용하십시오.
  1. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Lever and Spring: 1 단계, 이미지 1/3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Lever and Spring: 1 단계, 이미지 2/3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Lever and Spring: 1 단계, 이미지 3/3
    • Make sure your the device is unplugged before starting this teardown.
    • The device used in this tear-down is missing the lever and spring.
    • Remove these items by lifting up on the lever until it pops out of place. The spring should come out easily.
  2. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Securing Screws: 2 단계, 이미지 1/3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Securing Screws: 2 단계, 이미지 2/3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Securing Screws: 2 단계, 이미지 3/3
    • Remove all of the screws on the back of the plastic covering.
  3. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Handle Casing: 3 단계, 이미지 1/1
    • Remove the plastic handle cover by lifting it straight up.
  4. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Circuit Securing Screw: 4 단계, 이미지 1/2 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Circuit Securing Screw: 4 단계, 이미지 2/2
    • Remove the small black screw that is holding the circuit board in place.
  5. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Power Cord: 5 단계, 이미지 1/2 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Power Cord: 5 단계, 이미지 2/2
    • Remove the power cord from the power port of the Waver by holding the port with one hand and pulling on the cord with the other hand.
  6. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Metal Heating Cylinders: 6 단계, 이미지 1/3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Metal Heating Cylinders: 6 단계, 이미지 2/3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Metal Heating Cylinders: 6 단계, 이미지 3/3
    • Remove the two metal cylinders by sliding them down the length of the inner soft cylinders.
    • The internal ceramic cylinders are very soft and tear easily. Be careful not to damage them.
  7. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Cylinder Securing Fixtures: 7 단계, 이미지 1/2 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Cylinder Securing Fixtures: 7 단계, 이미지 2/2
    • Remove the plastic cylinder holders by lifting them up and along the length of the cylinder.
  8. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Rear Metal Plate: 8 단계, 이미지 1/1
    • Similar to step 4, remove the back metal plate by sliding down the length of the intern cylinder.
    • The internal cylinder is very soft and tears easily. Be careful not to damage it.
  9. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Heat Control Dial: 9 단계, 이미지 1/3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Heat Control Dial: 9 단계, 이미지 2/3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Heat Control Dial: 9 단계, 이미지 3/3
    • Gently lift the circuit board and tilt it to the side.
    • Lift the dial straight up from the circuit board. It should come off easily.
  10. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Full Teardown: 10 단계, 이미지 1/1
    • Here are all of the safely removeavable components of the waver
Kyle Weeks
회원 가입일: 09/26/12
116 평판
안내서 1개 작성함
Cal Poly, Team 15-45, Forte Fall 2012 Cal Poly, Team 15-45, Forte Fall 2012 회원
CPSU-FORTE-F12S15G45
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 815
