주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Ring Glass Break Sensor 수리는 저희 서비스 설명서를 사용하십시오.
  1. Ring Glass Break Sensor Teardown, Ring Glass Break Sensor Teardown: 1 단계, 이미지 1/3 Ring Glass Break Sensor Teardown, Ring Glass Break Sensor Teardown: 1 단계, 이미지 2/3 Ring Glass Break Sensor Teardown, Ring Glass Break Sensor Teardown: 1 단계, 이미지 3/3
    • Features:
    • Glass Break Detector
    • Real-Time Notifications
    • Simple Setup and Simple App Connection
    • Uses three replaceable AA Batteries
  2. Ring Glass Break Sensor Teardown: 2 단계, 이미지 1/1
    • In the Box
    • Glass Detect Unit, User and informational Manuals
  3. Ring Glass Break Sensor Teardown: 3 단계, 이미지 1/3 Ring Glass Break Sensor Teardown: 3 단계, 이미지 2/3 Ring Glass Break Sensor Teardown: 3 단계, 이미지 3/3
    • Close up look at the Glass Break Sensor
    • Glass Break Sensor Microphone
    • Setup Button
    • Twist off bottom for access to the AA batteries
    • Pull Tab to enable the batteries to power the sensor
  4. Ring Glass Break Sensor Teardown: 4 단계, 이미지 1/1
    • Backside view of the ring Glass Break Sensor Enclosure
    • Double sided tape used for installation of the sensor
    • Mounting Holes are also available for on the backside/bottom of the sensor
  5. Ring Glass Break Sensor Teardown: 5 단계, 이미지 1/1
    • Twisting off the bottom of the unit shows the removeable batteries.
    • It is nice to see a security product with easily accessible and replaceable batteries
  6. Ring Glass Break Sensor Teardown: 6 단계, 이미지 1/3 Ring Glass Break Sensor Teardown: 6 단계, 이미지 2/3 Ring Glass Break Sensor Teardown: 6 단계, 이미지 3/3
    • Next, separate the top with a iFixit Opening Tool to get access to the electronics inside.
    • There are number of catches around the outside of the device. These catches popped loose fairly easily with the iFixit Opening Tool.
    • Once the top is removed, we get our first look at the internal PCB
  7. Ring Glass Break Sensor Teardown: 7 단계, 이미지 1/3 Ring Glass Break Sensor Teardown: 7 단계, 이미지 2/3 Ring Glass Break Sensor Teardown: 7 단계, 이미지 3/3
    • There is a single Philips #0 screw holding the PCB to the enclosure.
    • Remove the single screw allows the Internal PCB to be pried out with a Spudger tool
    • Internal PCB removed from the enclosure
  8. Ring Glass Break Sensor Teardown: 8 단계, 이미지 1/2 Ring Glass Break Sensor Teardown: 8 단계, 이미지 2/2
    • Close up view of the back side of the battery compartment that also supports the internal PCB
    • Power from the batteries is passed to the PCB via metal tabs
    • Tab on the enclosure interfaces to the slide switch on the PCB to cut power when the bottom of the enclosure is rotated to access the batteries
    • Battery Mating Connectors for the battery compartment metal tabs . The non-forced connectors allow for easy removal of the PCB from the enclosure
  9. Ring Glass Break Sensor Teardown: 9 단계, 이미지 1/2 Ring Glass Break Sensor Teardown: 9 단계, 이미지 2/2
    • With the internal PCB removed, we get our first look at the backside and front sides of the PCB.
  10. Ring Glass Break Sensor Teardown: 10 단계, 이미지 1/2 Ring Glass Break Sensor Teardown: 10 단계, 이미지 2/2
    • Close up view of the backside of the PCB
    • MEMS Microphone, Vesper VM3011 - World's First Adaptive ZEROPOWER Listening™ Digital Piezoelectric MEMS Microphone
    • Close up view of the MEMS Microphone
    • Switch/button operation is not documented
    • Power Shutoff Switch. When the bottom is rotated to access the batteries - this switch slides as the enclosure bottom is rotated to shutoff battery power to the PCB
  11. Ring Glass Break Sensor Teardown: 11 단계, 이미지 1/1
    • Close up view of the front side of the PCB
    • Setup button and environment protection gasket
    • Dust filter and protection cover for microphone port
  12. Ring Glass Break Sensor Teardown: 12 단계, 이미지 1/3 Ring Glass Break Sensor Teardown: 12 단계, 이미지 2/3 Ring Glass Break Sensor Teardown: 12 단계, 이미지 3/3
    • Close up view of some of the electrical components on the top side of the PCB. Other than the two large ICs on the topside of the PCB, the other components look to be related to power management and control
    • Syntiant, NDR101BQQF. Always-on Neural Processor. Used for detecting the breaking glass
    • Silicon Labs, RZ13M1442. Z-Wave Long Range Radio with ARM MCU
  13. Ring Glass Break Sensor Teardown: 13 단계, 이미지 1/2 Ring Glass Break Sensor Teardown: 13 단계, 이미지 2/2
    • Close up view of the Glass Break Sensor Antenna and Antenna matching network
    • Based on the Antenna Design, the radio is probably sub-GHz
    • Antenna Matching Network
    • Bandpass SAW Filter
  14. Ring Glass Break Sensor Teardown: 14 단계, 이미지 1/2 Ring Glass Break Sensor Teardown: 14 단계, 이미지 2/2
    • Close up view of the MEMS Microphone Port
    • Acoustic Foam surrounds the Microphone port, and the acoustic foam is capped off with a dust cover
  15. Ring Glass Break Sensor Teardown: 15 단계, 이미지 1/2 Ring Glass Break Sensor Teardown: 15 단계, 이미지 2/2
    • Teardown Exploded Views of the ring Glass Break Sensor
Robert Shuler
회원 가입일: 03/12/19
3,549 평판
안내서 11개 작성하였습니다
댓글 5개
Neat! Given that it uses a microphone, I wonder if playing the sound of breaking glass over a pair of speakers would accidentally set it off.
Ethan Zuo - 답글
Yes it would. That is probably how it is tested.
Robert Shuler -
No, it doesn't. Many people have tried but it's now a well-known fact in the Ring Community that the sensor can't be tested using this method. The agreed method is to carefully break a glass or a bottle in its vicinity which does set the alarm off.
Steven Erridge -
My basement windows are on the ground level, where an intruder could easily kick them in, so I decided to install the Glass Break Sensor there. Just in case, I installed a Ring Z-Wave Range Extender. I brought a couple of empty bottles, slope game a medium-sized pickle jar (also empty), and a large rock from my yard down into the basement because I didn't want to sacrifice any of my actual windows.
Ferrason Andreaa - 답글
Sometimes tossing a keyring full of keys in the air and catching them in your hand is enough to set of a glass break sensor for a test.
Robert Shuler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 29
전체 시간: 2,302
