소개
I've found a vacuum in my utility room. Since I almost never use it, I thought it was a good idea to see how it works... So let's go!!
해당 분해도는 수리 안내서가 아닙니다. Rowenta AC6221 수리는 저희 서비스 설명서를 사용하십시오.
The 4.8 Rowenta vacuum can be used for a variety of purposes.
It is charged through its pedestal. The power of the pedestal is:
Input: 230V - 50 Hz - 7W (AC)
Output: 7.5V - 300 mA (DC)
This vacuum has several parts:
The tip
The reservoir which holds the dust and debris
The engine (4.8V)
The pedestal
The power supply
From top to bottom, the reservoir contains 3 parts: the housing, container, and filter.
The wires of the vacuum are now visible.
The wires connect the charger light, switch,engine, and power wires.
The green box labels the engine.
The orange box labels one of the four batteries (4*1.2V)
The top of the circuit board contains components including capacitors, resistors, wires, and a chip.
The bottom side shows the tracks that connect the components.
Remove the screw securing the handle with a screwdriver.
Open the handle to see the inside using the flat screwdriver.
Warning: The handle is difficult to open
Warning: In this procedure, the handle was not opened to keep the vacuum intact.
At the bottom of the pedestal, remove the 4 rubber pieces.
Note: This step provides access to 4 Philips screws.
Remove screws using a screwdriver.
Inside the pedestal, the power cable separates into 2 wires. Each wire is connected to a conductive piece.
This completes the vacum cleaner teardown
해당 안내서 퍼가기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
미리보기
