주요 콘텐츠로 건너뛰기
Rowenta silent force extreme RO5931 main brush Teardown
필요한 것
  1. Rowenta silent force extreme RO5931 main brush Teardown, Unplug the vacuum cleaner: 1 단계, 이미지 1/1
    • Turn off the vacuum and unplug it from the outlet.
    • Unmount the main brush head from the cleaner pipe.
  2. Rowenta silent force extreme RO5931 main brush Teardown, Remove the top cover: 2 단계, 이미지 1/3 Rowenta silent force extreme RO5931 main brush Teardown, Remove the top cover: 2 단계, 이미지 2/3 Rowenta silent force extreme RO5931 main brush Teardown, Remove the top cover: 2 단계, 이미지 3/3
    • Unsnap the clips of the top cover with a small slot screwdriver.
    • Remove the top cover of the brush.
  3. Rowenta silent force extreme RO5931 main brush Teardown, Unscrew the two top Philips screws: 3 단계, 이미지 1/2 Rowenta silent force extreme RO5931 main brush Teardown, Unscrew the two top Philips screws: 3 단계, 이미지 2/2
    • Unscrew both Philips screws from the top of the brush.
  4. Rowenta silent force extreme RO5931 main brush Teardown, Unscrew security torx screws: 4 단계, 이미지 1/2 Rowenta silent force extreme RO5931 main brush Teardown, Unscrew security torx screws: 4 단계, 이미지 2/2
    • Unscrew both security torx screws.
  5. Rowenta silent force extreme RO5931 main brush Teardown, Remove the top of the brush head: 5 단계, 이미지 1/3 Rowenta silent force extreme RO5931 main brush Teardown, Remove the top of the brush head: 5 단계, 이미지 2/3 Rowenta silent force extreme RO5931 main brush Teardown, Remove the top of the brush head: 5 단계, 이미지 3/3
    • Smoothly and carefully take out the top of the brush head.
    • Take some time to search for the defect.
    • Remove broken pieces and repair if you can.
    • Clean up the inner parts of the brush with a smooth cloth. Remove dust, grains that could damage the inner parts of the brush.
  6. Rowenta silent force extreme RO5931 main brush Teardown, Check the handle of the brush retract is fixed: 6 단계, 이미지 1/2 Rowenta silent force extreme RO5931 main brush Teardown, Check the handle of the brush retract is fixed: 6 단계, 이미지 2/2
    • Push the retract button : the brush must be lowered.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
David
회원 가입일: 05/23/14
1,523 평판
안내서 5개 작성하였습니다
댓글 2개
My vacuum is similar to the one shown here. Only had it a few months, now the suction is not very good, and is not picking up. The cylinder is not spinning around. Any advice. Thanks in advance
vivaespana - 답글
I have a head the same and want to replace the joining hose and wish to know how to replace it as it has all holes in it and not sucking properly TIA
Toosje McWhirter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 26
전체 시간: 1,613
