주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Samsung Evergreen SGH-A667 수리는 저희 서비스 설명서를 사용하십시오.
  1. Samsung Evergreen SGH-A667 Teardown, Samsung Evergreen SGH-A667 Teardown: 1 단계, 이미지 1/2 Samsung Evergreen SGH-A667 Teardown, Samsung Evergreen SGH-A667 Teardown: 1 단계, 이미지 2/2
  2. Samsung Evergreen SGH-A667 Teardown: 2 단계, 이미지 1/1
    • Begin by prying off the rear battery-access panel.
  3. Samsung Evergreen SGH-A667 Teardown: 3 단계, 이미지 1/2 Samsung Evergreen SGH-A667 Teardown: 3 단계, 이미지 2/2
    • Remove battery pack and SIM card.
    • Remove the seven screws marked in red.
  4. Samsung Evergreen SGH-A667 Teardown: 4 단계, 이미지 1/2 Samsung Evergreen SGH-A667 Teardown: 4 단계, 이미지 2/2
    • Pry the case away from the body of the phone. Be gentle around the volume control, micro USB, and micro SD ports.
  5. Samsung Evergreen SGH-A667 Teardown: 5 단계, 이미지 1/2 Samsung Evergreen SGH-A667 Teardown: 5 단계, 이미지 2/2
    • Camera
    • Keyboard ribbon connector
    • Microphone
    • Remove the two screws marked in red to free the EMI shielding.
  6. Samsung Evergreen SGH-A667 Teardown: 6 단계, 이미지 1/1
    • The keyboard ribbon strings each of the pieces together, but the keypad flops right out on its own.
  7. Samsung Evergreen SGH-A667 Teardown: 7 단계, 이미지 1/2 Samsung Evergreen SGH-A667 Teardown: 7 단계, 이미지 2/2
    • Remove the six screws marked in red; they hold the keyboard to the sliding mechanism.
  8. Samsung Evergreen SGH-A667 Teardown: 8 단계, 이미지 1/3 Samsung Evergreen SGH-A667 Teardown: 8 단계, 이미지 2/3 Samsung Evergreen SGH-A667 Teardown: 8 단계, 이미지 3/3
    • Huzzah the sliding carriage is free—what's that? The funk of forty thousand years? This part of the phone never sees the light of day!
    • Remove the six screws circled in red.
    • Sometimes this screw is hidden by the ribbon cable!
  9. Samsung Evergreen SGH-A667 Teardown: 9 단계, 이미지 1/3 Samsung Evergreen SGH-A667 Teardown: 9 단계, 이미지 2/3 Samsung Evergreen SGH-A667 Teardown: 9 단계, 이미지 3/3
    • More plastic clips means a little more finagling to pry the front case off.
    • The work pays off with a snappy line-up.
  10. Samsung Evergreen SGH-A667 Teardown: 10 단계, 이미지 1/2 Samsung Evergreen SGH-A667 Teardown: 10 단계, 이미지 2/2
    • Gently flex the faceplate to loosen the adhesive's hold on the screen.
    • After loosening all edges, begin to peel the LCD from the plastic. When in doubt, stop, look, and listen; just like crossing the street.
  11. Samsung Evergreen SGH-A667 Teardown: 11 단계, 이미지 1/1
    • The sum of its parts
    • Use these steps in reverse to reassemble—a method tried and true!
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 24
전체 시간: 779
