소개
This guide will give you a quick look inside the Samsung GT-E2120 (a.k.a E2120). It shows how the phone comes apart and will give you a quick look inside. This teardown should not be used as a dissasembaly guide.
해당 분해도는 수리 안내서가 아닙니다 . Samsung GT-E2120 수리는 저희 서비스 설명서 를 사용하십시오.
Using your thumb, press down on the back of the device in a downward motion to open the back cover.
Remove the battery along with the sim card and Micro-SD card.
This phone can take up to a 2GB Micro-SD card and is great for storing music. It even has a FM radio!
For this step a matal spudger is used to release the clips along the bottom, top, and sides of the phone.
These clips can be found at the points marked in red.
Working from the top down, gently prying at the case the clips are easily dislodged.
When the bottom of the phone is reached it is a bit harder to pull the bottom clips off.
This can be made a tad easier by using the pointed end of the spudger to get in and under the case.
Once the case is lifted up slightly, you can get enough purchase under the clip and lift it off.
Be careful so you dont damage the motherboard!
해당 안내서 퍼가기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
단일 단계
전체 안내서
소형 - 600px
중형 - 800px
대형 - 1200px
미리보기
