해당 분해도는 수리 안내서가 아닙니다. Samsung Galaxy Ace 수리는 저희 서비스 설명서를 사용하십시오.
With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside)
Make sure your Micro SD card is removed from the device Micro SD card slot.
Disconnect the microphone using your fingers, be careful not to do too much pressure.
Disconnect the light sensor and ear piece speaker.To remove this use a plastic tool.
Disconnect the volume rocker, be very careful! They are very thin and glued with double-sided tape. If possible, use isesamo or something really thin!
Lift the logic board from the right side, be careful not cause any damage to gently rotate the LCD connector.
Now with a plastic tool you can disconnect the LCD connector.
Use a plastic tool or something sharp to lift the aluminum protection that serves to fix earpiece speaker and light sensor and remove it.
After lifting the connector of the touch screen (black tab), lift the cable carefully!
Press the home button to remove it. (This is not fixed,no material).
Heat the glass lens with a hot air gun, a tool insert after "isesamo" and slowly raise it.
Remove it.
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
미리보기
