ํด๋น ๋ถํด๋๋ ์๋ฆฌ ์๋ด์๊ฐ ์๋๋๋ค. Samsung Galaxy Ace ์๋ฆฌ๋ ์ ํฌ ์๋น์ค ์ค๋ช
์๋ฅผ ์ฌ์ฉํ์ญ์์ค.
With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside)
Make sure your Micro SD card is removed from the device Micro SD card slot.
Disconnect the microphone using your fingers, be careful not to do too much pressure.
Disconnect the light sensor and ear piece speaker.To remove this use a plastic tool.
Disconnect the volume rocker, be very careful! They are very thin and glued with double-sided tape. If possible, use isesamo or something really thin!
Lift the logic board from the right side, be careful not cause any damage to gently rotate the LCD connector.
Now with a plastic tool you can disconnect the LCD connector.
Use a plastic tool or something sharp to lift the aluminum protection that serves to fix earpiece speaker and light sensor and remove it.
After lifting the connector of the touch screen (black tab), lift the cable carefully!
Press the home button to remove it. (This is not fixed,no material).
Heat the glass lens with a hot air gun, a tool insert after "isesamo" and slowly raise it.
Remove it.
ํด๋น ์๋ด์ ๋ฃ๊ธฐ
ํด๋น ์๋ด์๋ฅผ ์ฌ์ดํธ/ํฌ๋ผ์ ์์ ์์ ฏ์ผ๋ก ํฌํจํ๋ ค๋ฉด ํฌ๊ธฐ๋ฅผ ์ ํํ๊ณ ์๋ ์ฝ๋๋ฅผ ๋ณต์ฌํ์ญ์์ค.
๋ฏธ๋ฆฌ๋ณด๊ธฐ
