주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Samsung Galaxy Buds Plus 수리는 저희 서비스 설명서를 사용하십시오.
    최종 결론
    • External assemblies are held together with clips instead of glue, making for a non-destructive entry process.
    • Disassembly can be accomplished with common prying tools and a Phillips screwdriver.
    • The earbuds use rechargeable coin-cell batteries that are easier than ever to replace.
    • Opening procedure is a bit unorthodox, and can cause cosmetic damage to the buds.
    • Careful prying is required throughout to separate components without tearing fragile cables or otherwise damaging the buds.
    수리 용이성 점수
    7
    수리 용이성 10점 중 7점
    (10은 가장 쉬운 수리를 뜻합니다)
Taylor Dixon
회원 가입일: 06/26/18
67,692 평판
안내서 94개 작성하였습니다
댓글 7개
Would be nice if you could ID the rest of the major IC’s too.
Sean Davis - 답글
where can I find replacement parts?
Michel - 답글
More wireless earbud teardowns, please! I would also like to see the Galaxy Buds+ drivers.
Mike Housholder - 답글
possible to swap in a higher capacity battery for the buds+ and the case to increase total usable time in between charging.
K T - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 25
30일 전: 155
전체 시간: 20,663
