주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Samsung Galaxy Note 4 수리는 저희 서비스 설명서를 사용하십시오.
  1. Samsung Galaxy Note 4 Teardown, Samsung Galaxy Note 4 Teardown: 1 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown, Samsung Galaxy Note 4 Teardown: 1 단계, 이미지 2/2
    • Remove the back cover. It comes off easily.
  2. Samsung Galaxy Note 4 Teardown: 2 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown: 2 단계, 이미지 2/2
    • Remove battery, SIM card.
    • Don't forget the S Pen.
  3. Samsung Galaxy Note 4 Teardown: 3 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 3 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 3 단계, 이미지 3/3
    • Remove the 16 screws all together on the middle housing. That is a lot of screws.
  4. Samsung Galaxy Note 4 Teardown: 4 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 4 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 4 단계, 이미지 3/3
    • Cut the adhesive sticker between the screen and the middle housing. It will be easier if you apply low heat degree less than 85℃. Be careful to avoid breaking touch panel.
    • Carefully flip the housing over and loosen the hidden tabs around the battery slot.
    • Loosen the middle housing and then push the front assembly--this may take a little extra effort.
  5. Samsung Galaxy Note 4 Teardown: 5 단계, 이미지 1/1
    • Separate front assembly from middle housing successfully.
    • The whole front assembly comes with motherboard, USB board, cameras, LCD screen and some other small components.
    • The back housing comes with power & volume button, headphone jack and loudspeaker. And except loudspeaker, other parts are easy to remove.
  6. Samsung Galaxy Note 4 Teardown: 6 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 6 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 6 단계, 이미지 3/3
    • Get the flex free from the adhesive underneath and remove headphone jack naturally.
  7. Samsung Galaxy Note 4 Teardown: 7 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 7 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 7 단계, 이미지 3/3
    • Unlike the Galaxy S5, the Note 4 power and volume buttons are easy to remove.
  8. Samsung Galaxy Note 4 Teardown: 8 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 8 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 8 단계, 이미지 3/3
    • Cut the adhesive between LCD screen and mid plate carefully. Especially care about the position of the flex very much.
    • The adhesive is in the red scale, it's strong and we had damaged the foil film on the back of the screen when cut the adhesive. Heat with a low degree will make easier.
    • Release the connectors from motherboard. The right one is S Pen sensor film connector and the left one is LCD screen connector.
    • You also can see the soft keys on the bottom side. So be careful when cut the adhesive, don't hurt that part.
    • At last, remove LCD screen assembly carefully.
  9. Samsung Galaxy Note 4 Teardown: 9 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 9 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 9 단계, 이미지 3/3
    • Release navigation button flex connector ,get it free from the adhesive on the mid-plate and remove it.
  10. Samsung Galaxy Note 4 Teardown: 10 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown: 10 단계, 이미지 2/2
    • Remove 2 pcs of signal flexes. And maybe different versions Galaxy Note 4 comes with different numbers of signal flexes. Possibly one or two.
  11. Samsung Galaxy Note 4 Teardown: 11 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown: 11 단계, 이미지 2/2
    • Twist off two screws securing motherboard and USB board at first.
    • Don't forget to release the earpiece speaker connector.
  12. Samsung Galaxy Note 4 Teardown: 12 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 12 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 12 단계, 이미지 3/3
    • Pry up the motherboard.
    • Release USB charging board from motherboard.
    • Finally, remove Galaxy Note 4 motherboard.
  13. Samsung Galaxy Note 4 Teardown: 13 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown: 13 단계, 이미지 2/2
    • By the way, remove rear camera from motherboard. Release the connector and can take the camera away easily.
  14. Samsung Galaxy Note 4 Teardown: 14 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 14 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 14 단계, 이미지 3/3
    • Now, it's the turn of front camera assembly.
    • Release the connector at first, and then get free the two clasps, at last remove the front camera with sensors together.
  15. Samsung Galaxy Note 4 Teardown: 15 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 15 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 15 단계, 이미지 3/3
    • Get recent apps button and back button free from the adhesive on the mid plate.
    • Pry up the USB charging board and remove it.
  16. Samsung Galaxy Note 4 Teardown: 16 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown: 16 단계, 이미지 2/2
    • Pry up and remove earpiece speaker.
  17. Samsung Galaxy Note 4 Teardown: 17 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 17 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 17 단계, 이미지 3/3
    • Vibrator comes with power button flex together.
  18. Samsung Galaxy Note 4 Teardown: 18 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 18 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 18 단계, 이미지 3/3
    • Remove volume button flex.
  19. Samsung Galaxy Note 4 Teardown: 19 단계, 이미지 1/1
    • Done.
Sophia
회원 가입일: 03/25/14
43,708 평판
안내서 62개 작성하였습니다
26 Comments
horrible.
what happened Samsung? Why suddenly screw with repairers?
pseudonymous - 답글
Samsung has gone from the most repairable telephones to one of the worst.
I'd also like to note @ Step 8. Be VERY careful of the menu respectively the return key flexes located at the bottom of the screen while seperating the LCD from the chassi. They tend to "follow with" the sceren and break.
If they do break you'll have to replace the entire charging contact in order to restore them to full function.
Alexander - 답글
Thnx For The Important Tip
iABDOzz Mustafa -
Can you fit interior of note 3 inside chasis of note 4
Eddy Kelemis - 답글
ever make any progress with getting that note 3 to fit in the note 4 chassis?
wqhj studios -
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 48
30일 전: 221
전체 시간: 162,774
