주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Samsung Galaxy Note 4 수리는 저희 서비스 설명서를 사용하십시오.
  1. Samsung Galaxy Note 4 Teardown, Samsung Galaxy Note 4 Teardown: 1 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown, Samsung Galaxy Note 4 Teardown: 1 단계, 이미지 2/2
    • Remove the back cover. It comes off easily.
  2. Samsung Galaxy Note 4 Teardown: 2 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown: 2 단계, 이미지 2/2
    • Remove battery, SIM card.
    • Don't forget the S Pen.
  3. Samsung Galaxy Note 4 Teardown: 3 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 3 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 3 단계, 이미지 3/3
    • Remove the 16 screws all together on the middle housing. That is a lot of screws.
    My galaxy note 4 would not turn on. When it was opened up it had 15 screws and in the upper right hand corner there was a brass rivit. While trying to drill the display was broke.
    Have you ever heard of a rivit replacing a screw by Verizon or Samsung.
    The phone was a replacement under warranty.
    I mean, ... what the F xxxx !!!
    Steve Hartman - 답글
  4. Samsung Galaxy Note 4 Teardown: 4 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 4 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 4 단계, 이미지 3/3
    • Cut the adhesive sticker between the screen and the middle housing. It will be easier if you apply low heat degree less than 85℃. Be careful to avoid breaking touch panel.
    • Carefully flip the housing over and loosen the hidden tabs around the battery slot.
    • Loosen the middle housing and then push the front assembly--this may take a little extra effort.
  5. Samsung Galaxy Note 4 Teardown: 5 단계, 이미지 1/1
    • Separate front assembly from middle housing successfully.
    • The whole front assembly comes with motherboard, USB board, cameras, LCD screen and some other small components.
    • The back housing comes with power & volume button, headphone jack and loudspeaker. And except loudspeaker, other parts are easy to remove.
  6. Samsung Galaxy Note 4 Teardown: 6 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 6 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 6 단계, 이미지 3/3
    • Get the flex free from the adhesive underneath and remove headphone jack naturally.
  7. Samsung Galaxy Note 4 Teardown: 7 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 7 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 7 단계, 이미지 3/3
    • Unlike the Galaxy S5, the Note 4 power and volume buttons are easy to remove.
    Hi
    I bought back camera for note 4 from eBay but when I finish fixit its show me camera not found any one have idea how I fix this
    abdullah b - 답글
  8. Samsung Galaxy Note 4 Teardown: 8 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 8 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 8 단계, 이미지 3/3
    • Cut the adhesive between LCD screen and mid plate carefully. Especially care about the position of the flex very much.
    • The adhesive is in the red scale, it's strong and we had damaged the foil film on the back of the screen when cut the adhesive. Heat with a low degree will make easier.
    • Release the connectors from motherboard. The right one is S Pen sensor film connector and the left one is LCD screen connector.
    • You also can see the soft keys on the bottom side. So be careful when cut the adhesive, don't hurt that part.
    • At last, remove LCD screen assembly carefully.
  9. Samsung Galaxy Note 4 Teardown: 9 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 9 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 9 단계, 이미지 3/3
    • Release navigation button flex connector ,get it free from the adhesive on the mid-plate and remove it.
  10. Samsung Galaxy Note 4 Teardown: 10 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown: 10 단계, 이미지 2/2
    • Remove 2 pcs of signal flexes. And maybe different versions Galaxy Note 4 comes with different numbers of signal flexes. Possibly one or two.
  11. Samsung Galaxy Note 4 Teardown: 11 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown: 11 단계, 이미지 2/2
    • Twist off two screws securing motherboard and USB board at first.
    • Don't forget to release the earpiece speaker connector.
  12. Samsung Galaxy Note 4 Teardown: 12 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 12 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 12 단계, 이미지 3/3
    • Pry up the motherboard.
    • Release USB charging board from motherboard.
    • Finally, remove Galaxy Note 4 motherboard.
    and what the names of these small circuits glued to the side of the chassis next to the volume button?
    elisangelodark - 답글
    where can I buy a motherboard of my note 4? My motherboard is defective and needs to be replace. I bought my note 4 from Singapore 2 yrs ago. thanks for your help.
    Michael - 답글
  13. Samsung Galaxy Note 4 Teardown: 13 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown: 13 단계, 이미지 2/2
    • By the way, remove rear camera from motherboard. Release the connector and can take the camera away easily.
  14. Samsung Galaxy Note 4 Teardown: 14 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 14 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 14 단계, 이미지 3/3
    • Now, it's the turn of front camera assembly.
    • Release the connector at first, and then get free the two clasps, at last remove the front camera with sensors together.
  15. Samsung Galaxy Note 4 Teardown: 15 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 15 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 15 단계, 이미지 3/3
    • Get recent apps button and back button free from the adhesive on the mid plate.
    • Pry up the USB charging board and remove it.
  16. Samsung Galaxy Note 4 Teardown: 16 단계, 이미지 1/2 Samsung Galaxy Note 4 Teardown: 16 단계, 이미지 2/2
    • Pry up and remove earpiece speaker.
  17. Samsung Galaxy Note 4 Teardown: 17 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 17 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 17 단계, 이미지 3/3
    • Vibrator comes with power button flex together.
    The screen repair place I went to used too much adhesive and it damaged my power button. Here's the replacement part: ttps://www.amazon.com/gp/aw/d/B0149VUM4E
    Steve - 답글
  18. Samsung Galaxy Note 4 Teardown: 18 단계, 이미지 1/3 Samsung Galaxy Note 4 Teardown: 18 단계, 이미지 2/3 Samsung Galaxy Note 4 Teardown: 18 단계, 이미지 3/3
    • Remove volume button flex.
  19. Samsung Galaxy Note 4 Teardown: 19 단계, 이미지 1/1
    • Done.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 26개
horrible.
what happened Samsung? Why suddenly screw with repairers?
pseudonymous - 답글
Samsung has gone from the most repairable telephones to one of the worst.
I'd also like to note @ Step 8. Be VERY careful of the menu respectively the return key flexes located at the bottom of the screen while seperating the LCD from the chassi. They tend to "follow with" the sceren and break.
If they do break you'll have to replace the entire charging contact in order to restore them to full function.
Alexander - 답글
Thnx For The Important Tip
iABDOzz Mustafa -
Can you fit interior of note 3 inside chasis of note 4
Eddy Kelemis - 답글
ever make any progress with getting that note 3 to fit in the note 4 chassis?
wqhj studios -
are the note 4 screws the same as the one in LG G4 (specifically ls991)
Kachinga Mulenga - 답글
hi my note 4 screen was broken.. needed to replace the lcd.. now the new touch screen itself is working but the menu and back buttons aren't working properly (HOme button in the middle is alright) .. menu/back buttons light up and they do work but with some pressure.. they are not working with the ease and light touch they used to... what is wrong ?? what can I do to fix it ??
Sudip Barua - 답글
This was good guide and good photos. The Note 4 is adhesive nightmare, but with these photos and directions and a heat gun and patience, I was able to replace my USB charger board and put everything back together and functional again. Thank you.
findmint - 답글
You missed a step: SIM Connector Board removal/replacement
h.ringelberg - 답글
wheres the harddrive?
Cole Askin - 답글
Do you mean the internal flash? It is on the backside of the mainboard, soldered directly on top of the application processor (PoP). RAM and NAND flash are in the same package.
Zoé Bőle -
In you photos there seems to be parts from different model:
Headphone jack 910F - Fornt camera 910C - Usb charging board 910G
My board in my 910V is gone i would like to replace with 910G is this possible?
Ned - 답글
This is a Model No. SM-N910U
Gabe -
I am extremely !#^&@@ that the bootloader is locked, and Samsung doesn't let you run your own software on your own device anymore.
Zoé Bőle - 답글
Bootloader unlock is working on all devices now I think… even Verizon. There’s a huge thread over on XDA that details all the steps necessary to get temp root and unlock bootloader for Verizon devices. I managed to get a custom recovery and from there you can flash just about anything you want.
Aspen Watson -
Hii my the flashlight on my note edge is not working and they said it's a hardware problem where can I get and at which price
Lillian Mpanda - 답글
Hi,
My note 4 spen is not writing properly. When I draw the line then it tears and draws on gaps.
Touch is also the same. It works some places and doesn't work at other.
What should i do?
Hardy - 답글
i having problems with the usb port uff hope can fix it soon,
Jorge Franco - 답글
Hi, is it likely that the touch screen problem can be rectified by replacing the screen?
This one has pretty severe screen burn already but they aren’t cheap.
Andre - 답글
The note 4 mainly focuses on attracting the various individuals in a very short span of time. Even these individuals initiated and shown interest in buying the product for every regular interval successfully. I am also Facing Note 4 not charging problem. Finally i am fixed this problem. I refer one one website check out there.
catsfud - 답글
I’m a complete novice and wanted to know if the Fast Charger is a cord, module, or some sort? I recently installed another charging port on my Galaxy Note 4 not too long ago, and when I did the Fast Charge stopped working and the charging port itself charges slowly. Thanks.
Richie Johnson - 답글
Hi my name is Ali,
I wanted to know that WIFI and Mobile Data connectivity components are same or different in this mobile. I am facing problem with sim card data connectivity where as sometimes this function works OK and other times it does not work at all.
WIFI is working fine. Shall be grateful for reply.
Ali Noor - 답글
can u help ? i can replace my n910g board with n910c board
Vishnu Shaji - 답글
hey .. where you able to replace the boards ? are there any compatibility issues ?
another-user -
I only did through Step 4 to clean my volume button and it cracked my digitizer and bricked my phone.
Heather Welborn - 답글
Trying to find the UV/SpO2 sensor ribbon as the latter has failed on my Note 4.
Its failing the self test but the UV sensor is evidently still fine.
Also watch out, like many phones the OLED is glass and *very* easy to damage.
Xylene supposedly can help as the sticky regains its strength once this evaporates.
YMMV !!
Andre - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 96
전체 시간: 164,646
